Old 07-28-2014, 12:50 PM   #1
FLYNAVY30
Neutral Safety Switch???
Im using a painless harness on my '72 C20 that Im swapping a carb'd LS1 4L60E into. The thick purple wire going to the ignition switch has a break in it for the neutral safety switch but no amplifying information on how to wire it.
I realize the intent, but did these trucks come with a NSS from the factory? If they did, Id like to know how to properly wire it, if not, Ill just connect the wire and bypass the switch.
Thanks for the help!
FLYNAVY30 is offline   Reply With Quote
Old 07-28-2014, 01:31 PM   #2
Low Elco
Re: Neutral Safety Switch???
Yes, clipped on to the column under the dash.
Low Elco is offline   Reply With Quote
Old 08-03-2014, 01:03 AM   #3
EightiesOnly
EightiesOnly's Avatar
Yep it uses a connector that plugs into the top of it.
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 08-11-2014, 08:44 PM   #4
FLYNAVY30
found it, all is well....hoping for first start up tomorrow...thanks!!
