Old 07-28-2014, 04:46 PM   #1
hanly2
Couple questions on gas tank and oil pan/dipstick
Ok I just got my truck home and was finally able to look at some stuff, for some reason on the way home about 1.5hrs the fuel gauge did not move, but it worked before. Then when I got home I took the gas cap off and it sucked in a ton of air, and now the guage is reading again. Also, the dip stick broke off on me because someone had bent it all up. It is a mr gasket dip stick but whoever hooked it all up cut it so that it only reads at the full mark which I do not like, so I would like to buy a new one but not sure of the length it should be. I took a picture of the oil pan. I also tried the stick from my 77 c2500, and I think it was too long.
hanly2 is offline   Reply With Quote
Old 07-28-2014, 05:25 PM   #2
cdowns
cdowns's Avatar
Re: Couple questions on gas tank and oil pan/dipstick
taking your gas cap off and it sucking a ton of air is an indication that your tank is not vented properly and will cause you problems in the future
Old 07-28-2014, 06:41 PM   #3
hanly2
ok that sounds good, so what do I need to check? This truck is new to me. I also think that the oil pan is a 7qt oil pan from ebay. So I am going to need a lot of oil. But what dipstick should I use?
Old 07-28-2014, 07:42 PM   #4
michael bustamante
michael bustamante's Avatar
How come you think its a 7 quart pan? Does it have a deep sump? Nevermind. I just saw the pic. Summit can help you out with a dipstick.
What year is the truck and what size motor?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-28-2014, 08:05 PM   #5
hanly2
its a 350. not original to truck. I picked up a mr. gasket dipstick, I will drain and fill and check and see if that works. Thanks.
Old 07-28-2014, 09:05 PM   #6
Acorn
That is the best way to do it. When you change the oil, (be positive that it is a 8 qt pan first) use your '77 dipstick and start with six quarts. Mark the dipstick. Add another quart and mark it again. That will give you your low and full marks. Then if the '77 dipstick is to long, cut it down and put some plasti dip on the end.
Are there any part numbers on the old dipstick?
Also get a vented gas cap.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 07-29-2014, 07:59 AM   #7
cdowns
cdowns's Avatar
me i'd check into buying a stock 5quart oilpan and a stock dipstick for ease of mainenance in the future
Old 07-29-2014, 09:44 PM   #8
hanly2
I drained almost 10qts of oil from it. Ouch. Then i filled up the filter and added 7qts to the pan an the mr. Gasket dipstick still reads low. I hope i didnt do to much damage. And that the leak disapears.
Old 07-30-2014, 09:39 AM   #9
airdale94
airdale94's Avatar
You should be able to use a stock dipstick for the engine. The full level should not change with a deep sump pan. Only the amount oil to bring you to full.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 07-30-2014, 09:39 PM   #10
hanly2
That makes perfect sense, but for some reason it didnt work. Its about 1" past stock full level.
Old 07-30-2014, 11:41 PM   #11
airdale94
airdale94's Avatar
I have a Mr. Gasket chrome stick. Had the original stick but it broke as yours did. It's off also. Just empty it, fill and mark your stick. Looks like that pan was orange. May be a ebay special or a TransDapt pan, I think they paint there stuff orange. A stock pan is not actually 5qts. It's 4qts. plus the filter = 5qts.
Actually looks like it may be this Summit.
http://www.summitracing.com/parts/sum-g3502
You could do like Acorn said and, drain it, put 6qts. in it and mark Low, then put 1 more in it and mark Full. I used an electric tool engraver on mine. Mine reads fuller because my full mark is now my add mark.
