Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-28-2014, 04:56 PM   #1
glljr
1/4 mile
Finally got the truck to the track and quickest pass was a 12.7 at 107 mph with a 2.003 60 ft. Trying to get it down to 12.5 or under any ideas would help. I am running a 295/65/15 mickey Thompson drag radian with 15 psi in them.
glljr is offline   Reply With Quote
Old 07-28-2014, 05:05 PM   #2
dinnut
dinnut's Avatar
Re: 1/4 mile
What do you have for rear gears and a converter? Looks like theirs an easy 2 tenths to be had in the 60 foot. What is the engine setup?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 07-28-2014, 05:07 PM   #3
glljr
Re: 1/4 mile
its a 400 sbc with weiand 177 6 psi boost 3.73 gears turbo 350 trans and tci 3500 converter
Old 07-29-2014, 01:57 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 1/4 mile
Cal tracs for leaf springs.
If its truck arm read up on super 73's post's
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 07-29-2014, 05:00 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1/4 mile
Every tenth in 60'= about 2/10's down track .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-29-2014, 10:44 AM   #6
Super73
Super73's Avatar
Re: 1/4 mile
What year truck?
What has been done to the suspension? (Shocks/springs)
How are you doing your burn out? How long and are you rolling out of it?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-29-2014, 11:47 AM   #7
glljr
Re: 1/4 mile
its a 71 longbed stock shocks and lowering springs, not doing a huge burnout but am rolling out
Old 07-29-2014, 02:34 PM   #8
Super73
Super73's Avatar
Re: 1/4 mile
Assuming it is a trailing arm and not leaf?
Front lowering sporting is not helping transfer weight to the rear. Too short/stiff.
How long of a burn out, 5 sec then rolling out?
Old 07-29-2014, 04:38 PM   #9
glljr
Re: 1/4 mile
it is a coil spring rear, and probly about 5 sec burnout
Old 07-29-2014, 06:21 PM   #10
71Dragtruck
71Dragtruck's Avatar
Re: 1/4 mile
Is it even spinning, or just a dog out of the hole?
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-29-2014, 09:24 PM   #11
glljr
Re: 1/4 mile
Spins a little then hooks up
Old 07-29-2014, 09:36 PM   #12
Super73
Super73's Avatar
Re: 1/4 mile
Sounds like you need a different front spring to start. Do toy know what it weighs? Front and rear axle weights would be most helpful.
Old 07-29-2014, 09:36 PM   #13
71Dragtruck
Re: 1/4 mile
I'd try a set of pure slicks and try to bring up your launch RPM a bit so you are into a bit of boost.
Sponsored by:
Hard Candy Customs
Old 07-29-2014, 09:48 PM   #14
glljr
Re: 1/4 mile
http://m.youtube.com/watch?feature=y...&v=vZmjK0RmwoY
Here is a link to the pass not the best video
Old 07-29-2014, 11:35 PM   #15
Super73
Super73's Avatar
Re: 1/4 mile
A 177 being a smaller roots blower should be building boost pretty fast. I would assume at 3500 rpm it is doing good making torque.
A slick might help, but you still run the issue of not transferring weight to the rear. I used to have lowering springs and I don't now.
Your radial is not much smaller than mine, they work just fine if you can tune the suspension which you can't right now.
Old 07-29-2014, 11:40 PM   #16
Super73
Super73's Avatar
Re: 1/4 mile
Just watched the video.
What gear are you doing your burn out?
It is hard to see in the video but it sure looks like it leaves flat and doesn't transfer. I watched the video a few times.
Old 07-30-2014, 07:38 AM   #17
glljr
Re: 1/4 mile
1st gear burnout and it does leave flat
Old 07-30-2014, 01:00 PM   #18
Super73
Super73's Avatar
Re: 1/4 mile
You need to get more heat in that tire. 1st gear burn outs will not spin it fast enough. Get it in high gear with 5k rpm add quick as you can. That alone well help the reaction issue, might not take it away completely.
Old 07-30-2014, 01:23 PM   #19
glljr
Re: 1/4 mile
I'm heading back again friday I'll heat them up more and see what happens
Old 08-02-2014, 10:43 AM   #20
Super73
Super73's Avatar
Re: 1/4 mile
Did you make it back to the track last night like you were thinking?
Old 08-03-2014, 09:24 PM   #21
glljr
Re: 1/4 mile
No got rained out
Old 08-03-2014, 11:19 PM   #22
Super73
Super73's Avatar
Re: 1/4 mile
Bummer.. was hoping to see a new best.
