Old 07-28-2014, 05:33 PM   #1
Liftedchevrolet
Battery problems
Does anyone know why my battery dies after starting my truck only twice? It's a brand new battery.
Liftedchevrolet is offline   Reply With Quote
Old 07-28-2014, 07:22 PM   #2
jordanblea
Re: Battery problems
What's the status of the alternator? I'd start there. Might be a parasitic draw as well somewhere. Did the problems start AFTER the new battery or did you buy a new battery because you were having problems with the old battery?
It had to be done.
jordanblea is offline   Reply With Quote
Old 07-28-2014, 07:39 PM   #3
michael bustamante
michael bustamante's Avatar
How is the alt. Wired? Is it an internally regulated?
1967custom
michael bustamante is online now   Reply With Quote
Old 07-28-2014, 07:50 PM   #4
Lee H
Lee H's Avatar
How does it take to die?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-28-2014, 07:52 PM   #5
Liftedchevrolet
Got the alternator tested at advance auto parts. All good. Before I got the new battery the old one had short circuited. Then the starter went. I think there could be something pulling current. There is a switch in the truck which is supposed to turn all electronics off. I don't know if this switch could be bad?
Old 07-28-2014, 08:25 PM   #6
jordanblea
Go buy a $6 test light and start checking!!!
It had to be done.
Old 07-28-2014, 08:45 PM   #7
Liftedchevrolet
Can I use that to check the switch too?
Old 07-28-2014, 08:55 PM   #8
jordanblea
You can check power to the switch. It's a good tool to have either way.
It had to be done.
