Old 07-29-2014, 01:15 AM   #1
DMO
brake booster?
I'm dropping the front of my 66 and adding disc brakes. I was told I need a brake booster. I purchased one but the holes don't match up with the factor master cylinder.
1. Do I need the brake booster?
2. if I do need the booster do you have suggestions on how to mount booster to firewall?
Thanks!
DMO is offline   Reply With Quote
Old 07-29-2014, 01:29 AM   #2
Slow Build
Slow Build's Avatar
Re: brake booster?
You can't use the factory single output master cylinder when installing discs on front.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 07-29-2014, 01:44 AM   #3
DMO
Re: brake booster?
I purchased the drop spindle and disc brake conversion kit from ECC. Can I use that master cylinder and prop valve w/out the booster?
Old 07-29-2014, 02:00 AM   #4
Slow Build
Slow Build's Avatar
Re: brake booster?
Check out this thread.
http://67-72chevytrucks.com/vboard/s...aster+cylinder
Past GM Trucks:
Old 07-29-2014, 09:48 AM   #5
1963c-10
1963c-10's Avatar
Re: brake booster?
The brake booster is optional. I'm running manual disk brakes. The important thin is that you have the correct master cylinder for your application. IE.....disk/disk, disk/drum, drum/drum
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
