Old 07-29-2014, 09:39 AM   #1
Jimal
Jimal's Avatar
Man, these steering wheels are on good
Yesterday I attempted to pull the steering wheel off the column I picked up last week, because I want the wheel and I may have the column sold. All I accomplished was snapping the heads clean off two of the correct size bolts that came with my Mac steering wheel puller when I bought it 25 years or so ago. Considering my previous experience is with Volkswagens, where you take the bolt off, wiggle the wheel a few times and it falls off, this wasn't not expected.
Everything is loose and I can see the splines, so I don't think I've forgotten to take anything off... have I? I'm running out to get some Grade 8 bolts tonight.
Jimal is offline   Reply With Quote
Old 07-29-2014, 09:42 AM   #2
cortcomp
cortcomp's Avatar
Re: Man, these steering wheels are on good
Try getting it snug against the puller, put some pressure on it, then tap on the head of the puller, and then snug again, then do it again, etc, see if that helps you.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-29-2014, 09:45 AM   #3
LT1 Burb
LT1 Burb's Avatar
You need grade 8 bolts , get it real tight and hit the center part of the puller with a 20# hammer, I have had those grade 5 ones bend almost in half before.
LT1 Burb is offline   Reply With Quote
Old 07-29-2014, 10:11 AM   #4
el minero
el minero's Avatar
Use your favorite flavor of penetrating oil. Mine was a bear to get off when I did my blinker switch. Be careful with that puller though. I had so much force on mine I mushroomed the shaft and had to file it down and thread it again. Be patient, you'll get it off.
el minero is offline   Reply With Quote
Old 07-29-2014, 03:46 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
It helps if you unscrew the nut, but leave it on the steering column shaft flush with the top of the threads. Then slip a piece of solid steel in between the top of the nut and the bottom of the puller bolt. This will prevent deforming the shaft if you whack the puller with a hammer.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-29-2014, 03:55 PM   #6
66Submarine
66Submarine's Avatar
I knew my 16lb sledge was too light.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-29-2014, 11:22 PM   #7
66LSx
66LSx's Avatar
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-30-2014, 06:19 AM   #8
Jimal
Jimal's Avatar
This is pretty much what I did. Finally broke things loose last night. Thanks for the pointers everyone.
