Transmission hump
I got a question about transmission humps. what type of trucks used the tall humps was it just manual transmission and 4x4s. where they ever used on a 2wd big block auto.
Thanks |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: Transmission hump
I believe the bolt-in high humps were 4x4 and big block only.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Roadtrip!
![]() Join Date: Feb 2003
4x4 or 4 speed or big block with auto trans trucks got them.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Thanks for the help my 72 stepside is missing the hump and I was curious if it was correct for a big block auto
Only the 3 speeds had the small hump.
67-72 parts collector,…
![]() Join Date: Nov 2002
And TH-350 and Powerglide automatic trucks.
If your truck is missing the hump and the high hump is the only one that bolts in wouldn't that narrow the field? My 68 GMC is a high hump it was 396 T400 it also is/was a 3/4 ton. I prefer the high hump as for the look inside as compared to the low one that is one reason when my 70 3oot is changed to the T-5 I am doing it back with a high hump as well. Jim
Thanks I didn't realize the high hump was the only one that bolts in
![]() Join Date: May 2010
I didn't realize that the th350, th400 and the powerglide had low tranny humps well.
Scored a '72 Custom 20 with a rotted cab (I think I can lift the roof section off by hand!), but a nice high hump section. This will go into the '70 C10 T5/TPI set-up rather nicely.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
