07-29-2014, 01:10 PM | #1 |
Transmission drain plug on THM700R4
Hi,
86 Chevy C10 and 305 engine is being rebuilt as I write this. Took transmission off (THM700R4). Since draining transmission fluid was a pita, want to install aftermarket drain plug. What is the best location for that? Has anyone done this? I plan on brazing the plug in so no future issues with leaking etc. Is best place on the bottom? On the side of the pan? Since transmission is out, I don't know if I randomly chose a place to put it, it might interfere with some brackets, etc. when I bolt it back on the engine. If someone could take a picture of what it looks like under the truck without everything taken off, that would also help. Took it off some time ago and don't remember what it looked like. In the future, I will take pictures of everything before I disassemble things. Done this for the engine compartment, but nothing else. Live and learn..... Thanks |
07-29-2014, 02:55 PM | #2 |
Re: Transmission drain plug on THM700R4
Why not put a cast Aluminum pan with a drain plug already in it to replace the stock pan? If you put a drain in the stock pan put the drain so that all the fluid will drain out by putting the plug flush with the pan bottom.
07-29-2014, 07:04 PM | #3 |
Old Heap Driver
I welded mine in a flat corner area. Welded a bung on the outside of the pan for zero chance of any interference. If you're unable to locate a bung locally, just use a 1/2-20 jam nut as a bung, and the same size drain plug.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-29-2014, 09:54 PM | #4 |
Moderator
You can get a steel pan from Spectra, CFR, Dorman, or Summit with the bung and drain plug already installed.
The downside is they are thinner than the stock pan weighing in at 4-6 lbs. I believe the stock pan is prolly around 10-15lbs.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Tags |
thm700-r4, transmission drain plug |
