07-29-2014, 03:41 PM | #1 |
Reddington- My 60 SWB
Thought I would take a moment to introduce you to Reddington. He is a 60 SWB I found on CL out of La Grande Oregon. Nearest I can tell he was an old farm truck that a pretty rough life. On a positive note, the cab of the truck is remarkably solid. As for the bed... well that's another story. When I got him he barely ran, nothing worked, and everything absolutely filthy. I popped the valve cover off to find 5 out of the twelve push rods bent into pretzel shapes. Swapped all of them for a new set, rebuilt the carb, dumped all the old gas out and now he actually runs pretty good. After stripping out the bench and cluster and it took 2 sessions and a gallon on Super Clean to get the interior clean. You could see the brown nicotine stains dripping off EVERYTHING. So gross.
After rewiring the front and rear of the truck he is back to being road worthy. He made home under his own power last night and everything seem to be just fine. As I drove along he seemed to run better and better. Tranny seems smooth and quite. Clutch is good. Brakes work great. Still much work (and cleaning) to do but I super stoked to have him on the road. Enough with the babble. Here are a few pics! |
07-29-2014, 03:44 PM | #2 |
Re: Reddington- My 60 SWB
Great looking truck!
It only has original paint once |
07-29-2014, 04:28 PM | #4 |
That's a cool as truck!
07-29-2014, 04:31 PM | #5 |
Awesome find on the 60 short bed. Very cool that it still retains the original caps.
What are your plans for the truck?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-29-2014, 05:50 PM | #6 |
thats a awesome truck wish mine would fix that easy lol
Between saying and doing many a pair of shoes are worn out |
07-29-2014, 06:28 PM | #7 |
Nice looking truck!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
07-29-2014, 09:32 PM | #8 |
Nice truck and I like the stance. Are the rods cranked down or has it been switched over to coils?
07-29-2014, 09:41 PM | #9 |
WOW! Nice truck! I see dual carbs and fenton headers on that 6 banger!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-29-2014, 10:17 PM | #10 |
hello! looks to me it didn't have too much of a ruff life,that truck looks great. on second thought that thing looks a bit ruff. you can find one better. you should ship that thing east and let me dispose of it properly.
07-30-2014, 12:15 AM | #11 |
Nice !!!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
07-30-2014, 04:25 AM | #12 |
Thanks for the props folks! Yeah, its still on torsions. Plans are to lay it flat on the ground (air). The stock wheels, caps, and rings (16x4.5's for sale) are being replaced by a set of Cragar 69 Delux with bullet center caps and and lugs.
As for the 6, not sure what will be its fate. I am a V8 guy but it did come with a Ellis Duo-Power dual carb manifold. If I can get it run right it could be fun with a set of Fenton Headers and maybe a set of Lakes. We'll how this all plays out. Time and money will make all the decisions. LOL |
07-30-2014, 11:45 AM | #13 |
Lots of potential there! Let's see the interior.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
07-31-2014, 02:36 AM | #14 |
This after one (of which there were two) Super Clean and Pressure washer sessions. There was sooooo much nicotine stains on EVERYTHING. It dripped brown.
07-31-2014, 09:35 PM | #15 |
thats was saved for the hard times when you ran out of smokes, so you could just lick something in the interior when you had a niche for nicotine
08-01-2014, 02:02 AM | #16 |
I like
08-01-2014, 11:03 AM | #17 |
What is your plans for your interior? Are you going to keep the same color or change it to another? My 62 had the same color and I had the same problem when I washed the inside. Nicotine was everywhere in mine. Looking good!
08-01-2014, 11:35 AM | #18 |
Kool! Luv them 60-61s..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
08-01-2014, 01:28 PM | #19 | |
Thanks again for all the props folks! I usually buy these trucks to turn but I think I found a keeper!
Interior plans are to make it clean and comfortable. Fresh paint, sound deading, newer bench, full set of gauges (it happen to come with a deluxe cluster in the extra parts), carpet. I want the inside to be super fresh and clean but leave the outside battered. My only trouble is I am struggling with color. The stock black/silver really does nothing for me. Leaning towards white or an off white. |
08-01-2014, 08:49 PM | #20 |
I went with light drift metallic from dupli-color. It looks good and clean and most of all it was cheap. Here is a pic of the interior color. Sorry one of the pics is bad but you can get the idea. I hope this gives you a option. The seat cover is from Classic chevy and it is super easy to install.
08-02-2014, 01:23 AM | #21 | |
08-02-2014, 10:01 AM | #22 |
I had to do the same to mine. You might get lucky and they all are still there all you have to do is weld them back together. Good luck!
08-02-2014, 02:06 PM | #23 |
Man, I really like this truck! As much as I like hot rods and modified stuff, there's something about your truck that makes me love it just like it is, all the way down to the wheels and caps. It's got a really cool vibe that really hits home for me. I would have a really difficult time changing anything on that truck! Maybe a little lower all the way around and a wider rim in the back and add a rear bumper.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
08-03-2014, 01:56 AM | #24 | ||
He will go in stages. First up, a new set of shoes. |
08-03-2014, 09:56 PM | #25 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
