07-29-2014, 09:23 PM | #1 |
67 base rear end ratio
what is the most common gear ratio used on a 67 base truck with 6cyl/ three speed? no options except vinyl seat and deluxe heater. now that is pretty basic!!
07-29-2014, 09:53 PM | #2 |
Re: 67 base rear end ratio
411
07-29-2014, 11:28 PM | #3 |
Hey youre sescribing my truck. No frills! If someone can tell me how to count whhel rotations/ input shadt rotations ill do it in the morning and tell you
I hope its not 3:08
1967custom |
07-30-2014, 08:18 AM | #4 |
I would've thrown out 3.73, but I'm far from an expert. Here's a thread with rear end codes:
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
07-30-2014, 09:16 AM | #5 |
The majority of 3 speed trucks had the 3.73. The majority of automatics got the 3.08.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-30-2014, 09:22 AM | #6 |
Pretty sure it's 3.73.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
07-30-2014, 10:50 AM | #7 |
My 68 is a six 3 on the tree and 3.73 gears..
07-30-2014, 10:54 AM | #8 |
my 69 6 manual trans had 3.73
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
07-30-2014, 10:56 AM | #9 |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-30-2014, 09:51 PM | #10 |
Thanks to everyone for the info. The fellow I bought it from put a 5speed from a s-10 in the truck and it seems to be really low geared. I drive it everyday and I don't want to wind it's brains out!
07-30-2014, 09:55 PM | #11 |
It shouldn't rev very high with a 5 speed!
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
07-30-2014, 11:30 PM | #12 |
07-30-2014, 11:49 PM | #13 |
If you're used to listening to modern trucks with 3.55's or 3.73's with OD transmissions and 31" tires - i.e., a stock 90's Silverado 1500 Z-71 - it'll sound like it's screaming, but GM designed the small blocks of the 60's, 70's, and even through the mid 80's to thrive at 2,500-3,000 RPM. Yes, they run faster than modern vehicles, but that doesn't necessarily hurt longevity (nor fuel economy, as much as some will say) and gives you more of the engine's power without downshifting. Would I take my '85 C3500 (454/TH400, 4.10's) or '67 Suburban (350/NP435 4-speed/3.73's) and flog them down the interstate at 75 MPH for hours? No, but I'm not afraid of sustaining 65 and laying into them when I want to put a Honda in its place. GM trucks' reputation, from the sport utility boom of the 60's through the "Like a Rock" commercials in the 80's, didn't come from owners that kept their trucks under 60 MPH.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
07-31-2014, 12:15 PM | #14 |
Assume he's referring to lower gears, not od. 1st gear in an s10 t5 is pretty deep - some were over 4:1 ratio - to allow the little 4 cyl get the s10 moving. When adding more gears to the trans, the sweet spot for rear end ratio drivability narrows significantly. 3.42-3.73 range are the best choices for an od trans to keep highway rpm from getting too low while also not making 1st gear final ratio so deep you have to shift about 10 ft after you leave a dead stop.
