Bagging a 62
Anyone used the factory X frame of a 60-62 to bag their truck? I've seen back halves and 4 link setups but no factory bridge notches using the trailing arms or the like with the X frame.
We're using a 73-87 front coil suspension so that's cake, rear is a little tricky. Thanks in advance. |
Re: Bagging a 62
I pipe notched mine. Porter built trailing arms to center wheels and Panhard bar kit. Relocated shocks. All down just kiss top of axle.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Bagging a 62
There's a guy here that did the fronts.
He cut the torsion bars off at the lower arms. He then welded a steel plate to the bottom of the lower arm to mount the bag to.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Re: Bagging a 62
Re: Bagging a 62
Other truck pictures won't load so here are few more.
Who Me?
Re: Bagging a 62
I went the el cheapo route, but it works. Check my build thread.
Start at post #16.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Bagging a 62
Now its working! Here is one Justin built. Was in Car Kulture Deluxe.
Re: Bagging a 62
+1
#9 | |
Re: Bagging a 62
any more pics of it laid out to see how low it gets. my friend is doing the fab work and just finished a 64 and cross member is pancaked. the frame below the cab is the lowest point. that's what i need... |
