07-30-2014, 01:14 PM | #1 |
Big block headers for lowered pickup
Hey everyone I'm new here, I'm from wheatland ca, I'm in the process of putting a big block and th400 in my 69 c10 and I'm wondering what headers work best for this, my truck is lowered so I don't really want truck long tubes, thanks
07-30-2014, 01:25 PM | #2 |
Re: Big block headers for lowered pickup
hooker super comp long tubes are working fine for me. they sit even with the lower frame rail.
07-30-2014, 02:25 PM | #3 |
Truck headers?
07-30-2014, 02:31 PM | #4 |
yes truck headers. I can get a part number for them when I get home into the trucks file. I am using 72 and up mounts so I am not sure if that makes a difference for the 67-71 style. Tubes fit great no modifying tubes power brake and power steering truck. I do run an aluminum head raised port design that may bring the ports up a little bit
John |
07-30-2014, 03:01 PM | #5 |
I just bought yesterday the Hedman 69170's. My truck is a '70 with a big block, big block stands and mounts. I always have had a hard time finding a header where the z-bar will clear #7 primary. We'll see if this time is a charm.............
07-30-2014, 03:05 PM | #6 |
motor exploder
This will keep you busy for a while -
http://www.google.com/custom?domains...D%3A1%3B&hl=en Welcome to the board from Arkansas. I too have a big block in a '69 C10.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
07-30-2014, 03:15 PM | #7 |
it may help to specify which stands and mounts you are using.
I will get a photo of mine when I get home tonight. The Super comps work nice and they have a thick mounting flange to reduce warping. I also am using copper gaskets never had sealing issues. |
07-30-2014, 03:33 PM | #8 |
I got the proper big block mounts with the dip in them for the exhaust to clear, I bought some summit chevelle headers because I had read they fit these trucks but the passenger side hits the lower control arm and the frame rail, maybe because they are cheap summit headers
07-30-2014, 04:41 PM | #9 |
Here's my truck before and after
07-30-2014, 04:43 PM | #10 |
After I cut it in half
07-30-2014, 05:06 PM | #11 |
okay so they don't sit quite as high as I thought. but the control arms are lower still. I did have to drop the outlets down to clear the cross member for the transmission. Are you using the early or late mounts? That's also a big pan eight quarts.
07-30-2014, 05:35 PM | #12 |
I was going to get the early style but a friend of mine said he has the later style clam shell type with the through bolt so il be using those
07-30-2014, 07:11 PM | #13 |
those worked good for me on my 71 just spend the extra money and buy the 72 frame mounts. My headers don't bottom out but I only have a 3.0 front drop. All CPP spring and 4.0 in the rear also all spring no blocks.
The Hookers have 3/8 flanges so they don't warp and I use copper gaskets as stated. I am trying out a new set of collector gaskets made from graphite and steel. if they don't work well I may switch to a ball and socket style. providing I don't sell it first. |
07-30-2014, 11:29 PM | #14 |
Sanderson block huggers. They stay between the flanges of the C-channel frame from wheelwell to the collector flange.
07-30-2014, 11:33 PM | #15 |
Sanderson BB8's worked great for me. They are about a 3/4 length header, so you can tuck the exhaust up in the frame.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
07-31-2014, 12:18 AM | #16 |
2nd this
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
07-31-2014, 02:32 AM | #17 |
So chevelle headers dont work?I have heard over and over they do.
02-11-2015, 02:40 PM | #18 |
454 MAKES IT ROAR
Bump
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
02-11-2015, 04:04 PM | #19 |
Headman's worked for my factory BB...
1967 C10: My next project 1964 SS Impala Hardtop, low and slow 2007 Harley Street Glide .... When all else fails to start. |
02-14-2015, 08:47 PM | #20 |
I put a BB in my '71 project and used Stan's Headers. I have to pull the front tires on 2x10's to get a jack under the bumper and front cross member. I've had no issues with header clearance...
octane 1971 C10 Cheyenne - Project Truck 1971 C10 Super Cheyenne - Driver |
02-14-2015, 10:08 PM | #21 |
Here's the Hedman 69170 BBC headers. I'm running POL aftermarket mounts.
Driver's side:
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
02-14-2015, 10:10 PM | #22 |
Passenger side:
02-15-2015, 08:10 AM | #23 |
454 MAKES IT ROAR
There are obviously a few headers out there that work fine with BB lowered trucks, Headman seems to be a pretty popular choice, but I had heard that Hooker Super Comps for the Chevelle worked too, anybody got any info or pt #'s on those?
02-15-2015, 10:22 AM | #24 |
On the road
I have Hooker Comp #2455 long tube Chevelle headers on my 496, I have never drug them, lots of pics on my build page. These are 2" tubes with 3 1/2" collectors
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
02-15-2015, 02:42 PM | #25 |
454 MAKES IT ROAR
Cheers Mike looks real sweet. I would rather go 3/4 length so they'll be no issues when I eventually bag it.
