Bagged Bodied and Track Ready? Best of both worlds.
-I have a 70 C10 that is bagged and I am a real performance guy. I am building an LS swap and should make about 650hp on motor. I am really torn and wanted to ask some suggestions. I love the look of bodied trucks, but I also want to get the power to the ground and track. I would like in the long run to run nitrous on the motor and get street slicks to put down good runs.
-Is there a good way to have the best of both worlds? Can I body the truck and keep it bagged, but spruce up the frame and other suspension components to run at the dragstrip? I would like to have a ten second truck, and also body it with different wheels for weekend shows. Any thoughts? Thanks All. |
Re: Bagged Bodied and Track Ready? Best of both worlds.
I am sorry, I have nothing to contribute in answering your questions. And I have no desire to hi-jack your thread.
BUT, I need to know the specs on your wheels and those whitewall tires. I love the look and stance of your truck. ![]() Thanks much! -Ed |
what does "bodied" mean?
I got the truck with them on already. I think they are 15x7's with wide whites. Not sure the exact spec on the tire size. My guess would be like 195/60's or something close to that.
Boosted Member
650 hp on motor, eh? Flywheel hp or rear wheel hp? What are you building?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#7 | |
I just saw some pics of your motor. I love the turbo setup. Mind sharing what hp you are making? Last edited by abohler1; 07-30-2014 at 05:03 PM. |
build a" farm truck" he can lay the body....
sorry couldn't help it |
I don't have anything to contribute but interested in the responses so I'm going to follow along. I too am building a bagged/LS truck but doubt it'll be a ten second ride. Be cool if it did though.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
look in the suspension forum...there is a couple of LOOONNNGGG threads there
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#12 | |
Boosted Member
I've got a buddy right now building an ERL 454" sleeved motor for his C6Z. He bought Tony Mamo's personal heads and intake from the Vader motor (google it). Mine isn't any of that high dollar stuff, just a junkyard LQ4 ![]() Had it at the dyno this spring to baseline it. It put down 541 to the wheels on 9 lbs of boost (gate pressure) on 93 octane and 14 degrees of timing. That's somewhere around 625-650 flywheel hp depending on drivetrain losses. Planning to turn it up soon and switch back to corn. Shooting for 750ish at the tire. Regardless, I'm subcribed to this to follow the progress. Rock on.
#13 |
#14 | |
Good luck with your motor endeavors as well. Will keep an eye out for updates. |
