Old 07-30-2014, 05:11 PM   #1
AZ71Burban
AZ71Burban's Avatar
1971 Suburban lift kit help
I have a 1971 Suburban 2wd, I want to do a 3" lift. I don't know a lot about lift kits so I'm looking for suggestions. The plan is to lift it so I can fit some 33" tires on it. Thanks
{List of Toys}
2005 Nissan Frontier Nismo Edition
1972 Monte Carlo
1971 Chevy Suburban
AZ71Burban is offline   Reply With Quote
Old 07-30-2014, 09:58 PM   #2
Cobalt964ruf
Cobalt964ruf's Avatar
Re: 1971 Suburban lift kit help
try any of the vendors on here. they all seem helpful
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 08-01-2014, 12:30 AM   #3
4x4Poet
Lift a 2wd? Difficult, particularly the front IFS.
Others running dubs and such have been able to massage or trim inner fender skirts and fender lips to make room for larger diameter tires than stock. If you are planning on painting the burb anyway, sheet metal massage is worth investigating.
I've assumed you're not converting to 4x4.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-01-2014, 11:48 AM   #4
AZ71Burban
AZ71Burban's Avatar
No not converting to 4x4 I wanted to lift it to put on better off road tires and give me a little better ground clearance when on camping trips. Was thinking for using 3" spring spacers but I don't know how that would affect ride
{List of Toys}
1972 Monte Carlo
1971 Chevy Suburban
Old 08-04-2014, 01:37 AM   #5
Cumminpwr11
Southern Nevada Coal Roller
you can do a 3" body lift. Otherwise you will need to ask a local offroad shop. Custom lift spindles ran me $1200 for my old 2wd ram 2500 diesel the blocks for the rear leafs. Spindles will keep stock ride comfort.
Hope this helps.
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 08-04-2014, 09:10 AM   #6
ERASER5
ERASER5's Avatar
If you do a lot of converting, there are some later model 2X front lifts. There are no longer any 2X front lift packages for 67-72 2X trucks, or I would already have one. There are ways to mount the upper ball joint under the UCL instead of on top. With the needed spacer (probably custom built) you could get some lift. Big block springs will help a little. But bigger springs on gets you so far. Maintaining proper geometry and safety is paramount as well as difficult. Careful thought is necessary here.
However, 33" tire will fit under at factory height (no sagging). There may be some rub on the street, off road, there would be more rubbing. I would start there and modify as needed.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-06-2014, 12:31 PM   #7
AZ71Burban
AZ71Burban's Avatar
thanks im going to get some 33's and see how they ride. I found 3'' spring spacers for front and rear so I might just use those if I need to..
{List of Toys}
1972 Monte Carlo
1971 Chevy Suburban
Old 08-12-2014, 07:03 PM   #8
doc70sub
doc70sub's Avatar
Supposedly, there is a way to run '88-'98 GM truck spindle lifts by changing to a 3/4-ton lower a-arm & tie rod....
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 08-12-2014, 07:04 PM   #9
doc70sub
doc70sub's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=469743
Old 08-12-2014, 10:42 PM   #10
72MARIO
72MARIO's Avatar
I had a 3"spring lift...went back to stock after tearing the upper ball joint out of the control arm and destroying idler arms in under 5000 miles. Stick with a big block or HD spring any taller you have no droop left and the ride is terrible never mind the bump steer. best tire would be a 265 75 .
Your burb will still be fun and safe to drive.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-12-2014, 10:43 PM   #11
72MARIO
72MARIO's Avatar
285 75 16 rubbed on my truck with the 3" lift. Is you Burb a 1/2 or 3/4 ton ? spindle lift would be awesome my truck is 8 bolt I haven't figures how to get a spindle lift yet.
2005 TAHOE DD
Old 08-13-2014, 06:13 PM   #12
AZ71Burban
AZ71Burban's Avatar
1/2 ton with a 3/4 ton rear end I got some 33x10.5x15 tires on and they seam to sit good. Don't know how they ride because truck wont have a engine till end of the month. Looks good so far...
{List of Toys}
1972 Monte Carlo
1971 Chevy Suburban
