07-30-2014, 07:28 PM | #1 |
Steering Linkage a Prep/Paint
Looking for any suggestions in preparation and (rattle can) painting of new steering linkage (80 Camaro). Good scrub with solvent, prime (etch?), and paint? Recommended types? I know this is basic, but always get the good gouge here. Good news is that the frame is off for blast/powder coating!
Thanks, Jim |
07-30-2014, 09:44 PM | #2 |
Re: Steering Linkage a Prep/Paint
Clean good to get the grease and crud off. I use Simple Green in different strengths. If its bare metal etch primer works, if not just a good primer (I use Duplicolor) with Duplicolor #1634 High Temp. It is about a 40 percent sheen, not as shiney as semigloss, close to the Chassis Black single stage I used on the frame. Here are two photos showing the painted pieces and frame (dusty).
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-30-2014, 10:52 PM | #3 |
Orrie,
Was the Duplicolor Self Etching rattle can primer you used a light green? I ask because I originally used that on the body of my truck to getaway from the "standard" red oxide, light gray, flat black primer look. It worked good but didn't hold up exposed to air without a finish coat. No complaint, it isn't supposed to work like that but I didn't know. I'm a fan of Rustoleum mostly because I've had really good results and it is so easily touched up after the fact on a daily driven, non-show truck. If I were doing a little more high end truck I'd use a catalyzed automotive paint. And I suppose I could ADD a catalyst to ordinary Rustoleum and spray it.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
07-30-2014, 11:26 PM | #4 |
bowt1ed, I just got new steering linkage also. I got a couple of the red scuff pads, they have more scuff than the green ones.
Once I got the red scuff pads I kept them wet with lacquer thinner and scrubbed and scuffed the linkage. I primed with epoxy then painted. In your case, you should get a can of etching primer, then follow directions to the paint process. Good luck, Jim
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
07-31-2014, 06:14 AM | #5 |
Thanks guys! Always get good advise here. Seems like the tear down stage has taken me forever. So glad to be starting the build back up process.
