modifying control arms
i saw a set of modified control arms on ebay where the guy cut the lower control arm ball joint mount off and welded in plates to raise it 3 inches. will this work the same as drop spindles, and will you still have the suspension travel because I think the upper arm will be pushed up that much more, and lastly how safe would that be?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: modifying control arms
Drop spindles would be a MUCH better option.
![]() Join Date: Dec 2013
Do you really want to risk your life on someone else's welding skills when you can buy the correct parts ????? probably NOT a good idea !
![]() Join Date: Jul 2009
Doesn't seem like a very safe way to lower a vehicle. It would certainly screw up the geometry...
Drop spindles might be a bit more up front, but between the piece of mind related to safety and the simplicity of installation of spindles vs. control arms (no fighting the coil spring) more than offsets the cost difference in my mind. Just my .02¢ |
#5 | |
Some 'shade-tree' engineering stuff works pretty good. This, however, does not appear to be an instance of that.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
Biggest concerns I'd have, which would NOT be manifest with drop spindles:
1. Upper control arm would be much closer to the bump stops. 2. Altered camber curve making for weird handling behavior. 3. Potential for more bump steer. 4. The plate that raises the ball joint mount may not be capable of taking the bending loads under hard cornering. 5. This REALLY wouldn't be forgiving if your welding isn't up to par. Some of these depend on the quality of the work, but some would be unavoidable.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
stepped control arms have been around at least 30 years, when drop spindles became available most people stopped using them.
when done right they are just as safe as your factory arms
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
Agreed 100%.
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
Kinda what I thought too!
Maybe post a pic of these arms to get a better opinion of how they were done and if it would look safe to use them.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
