Old 07-31-2014, 11:37 AM   #1
ClassicGuy
Driveshaft question????
I've got a 70 c10 short bed. It came with a 2 piece driveshaft. I want to get a 1 piece built for it instead but before I do that, I would like to know if that is possible. It has the rear end off of a 72 c10 and a T400 transmission. Any advice is greatly appreciated. Thank you
ClassicGuy is offline   Reply With Quote
Old 07-31-2014, 12:21 PM   #2
Lee H
Lee H's Avatar
Re: Driveshaft question????
Sure, It's done all he time. Best advise I can give is go to one of the major drive line web sites, I like Inland Empire Driveline, and poke around. They have a few good videos and tutorials. Good luck with your project, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-31-2014, 01:06 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: Driveshaft question????
I just had a 1 peice put in my 71 LWB truck back in Januarary and love it.
I've driven it on the 2014 Hot Rod Power Tour back in June. I put 3300 miles on it in 7 days and not one issue.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-31-2014, 01:21 PM   #4
hamjet
hamjet's Avatar
I have a question, if its possible to put one piece shafts then why did GM use two piece?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 07-31-2014, 08:43 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
The 2 piece shafts use all of the same parts as the full size car shafts from the era.
The clearance around the control arm crossmember is pretty close for the diameter tubing required for a one pice shaft, especially at factory ride height.
Better question, why didn't they put a slip in the rear shaft on 2 piece driveshafts.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
