Old 07-31-2014, 01:45 PM   #1
lv2tri2
lv2tri2
I don't see why a shackle mount is necessary for the rear of the 47- ? chevy cabs. Can I just build another mount similar to the front?
lv2tri2 is offline   Reply With Quote
Old 07-31-2014, 05:09 PM   #2
MIKESAD50
Re: lv2tri2
My frame from Art Morrison came with a rigid mount on the frame so wont be using the shackle mounts. If you go to the art morrison site you can see them, or I can post a picture if you would like.
I havent mounted my cab yet.
MIKESAD50 is offline   Reply With Quote
Old 07-31-2014, 05:27 PM   #3
lv2tri2
Re: lv2tri2
I'll look at that right now and thanks I appreciate the help.
Old 07-31-2014, 07:14 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: lv2tri2
49 to 53 had them 47 48 did not, The shackle mounts are necessary if you use the original frame and no boxing. The frame flexes a lot on these trucks and will start cracking the cab spot welds apart. 47 1st and 48 had this issue with the center hung mount. I have a 47 in the shop now that had the entire rear cab seam split open at the floor level..
Art Morison frame is much stiffer so you could get away with no shackles.
dwcsr is offline   Reply With Quote
Old 07-31-2014, 09:40 PM   #5
lv2tri2
Re: lv2tri2
Thanks for taking the time to add this piece of GM history. I have a Tube frame so the shackles are not going to be used.
Old 08-01-2014, 11:13 AM   #6
MIKESAD50
Re: lv2tri2
here are a couple of pictures from my frame for the rear cab mounts both are the left side
Old 08-01-2014, 07:19 PM   #7
Advanced Design
Advanced Design's Avatar
Re: lv2tri2
Wow, that looks nice!
Advanced Design is offline   Reply With Quote
Old 08-02-2014, 12:33 AM   #8
lv2tri2
Re: lv2tri2
That's Morison's work, very nice. I may attempt to buy that mount from him. I can't bend large square and that's what this looks like it started as.
Old 08-02-2014, 12:36 AM   #9
sqrlnts
Re: lv2tri2
Impressive indeed, nice work.
sqrlnts is offline   Reply With Quote
