E.H.F.D Engine #2
72 K10 Front driveshaft question
Hello everyone. As I'm reinstalling the front driveshaft in my 72 k10, I've noticed pictures of many other trucks that are different than mine. I see most others have an extra u-joint and flange on the transfer case end, making for a total of 3. Mine has only 2 U-Joints that bolt directly into each yoke. I believe the truck has a 2" lift, but I don't think that should require a new front shaft. Has anyone seen one like mine without the flange? Should I look to replace mine, I don't plan on using the 4wd more than maybe one per year but it would be nice to make sure it works properly. Pictures are best I could do from way back in the teardown days...
Best pic I have, see where it connects to the t-case directly ![]() The style that I've seen elsewhere ![]()
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
user # 2756
![]() Join Date: Jun 2001
Re: 72 K10 Front driveshaft question
I have had a couple of these trucks and have always had a "double-cardian" joint at the transfer case. The older ones used the dana style and the newer ones used the sagnaw or flanged style. From what I can tell in your pic, typically the slip joint is always bolted at the axle not at the transfer case. I can take some pics of mine when I get home.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
![]() Join Date: May 2003
Yeah as Jim said; You should have a CV joint ( double u-joint ) at the transfer case and the slip joint down towards the diff.
I did have a shaft like yours on a truck temporarily until I got a replacement. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
why would you have the slip joint down in the mud and water? my tk only has 2 u-joints, one on each end plus the slip joint. don't have much axle movement though.
1961 chevy K10 my build is------------61K10 build |
![]() Join Date: May 2014
Here is a picture of mine, from my 72 SWB K10
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
I have seen people run without the cv joint but they should have them
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project Last edited by 67swb72klb; 08-01-2014 at 03:33 PM. |
#7 | |
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb ![]() |
E.H.F.D Engine #2
Interesting. I guess I'll have to look for the correct shaft. I wonder if I can just add the cv joint to the shaft I have?
![]() Join Date: Mar 2003
I happen to have a good cardian joint on a shaft I stole the spline from... $20 plus shipping.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
The shaft angle is improved slightly by adding the lift. It seems a PO thought it was enough to not need the CV joint. He may also have also spent some bucks converting from the flanged output to the ujoint output, which many feel is better.
Mark how the splined ends go together to keep it balanced, pop the shaft in two, clean, grease the splines and the ujoints and forget about it. BTW, stop looking at LMC catalogs for locally available common replacement parts. ![]() Last edited by franken; 08-01-2014 at 09:43 PM. |
20' Daredevil (Ret)
Good advice, and here's why, along with a good basic illustration of why DS angles need to be correct.
https://www.facebook.com/photo.php?v=470937339716400
#13 |
user # 2756
Mike, That is an awesome link. Thanks for sharing!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 08-04-2014 at 11:39 AM. |
#14 | |
E.H.F.D Engine #2
BTW- I stopped shopping at LMC many years ago but their catalogs are a decent source for parts pictures.
