Old 07-31-2014, 10:08 PM   #1
Caleb
Caleb's Avatar
Rear gear change question
well im new to the forum so if i posted in the wrong place please forgive me. i tried to navigate best i could. anywho main point. i have a 1984 GMC K1500 with a GM 12 bolt and im looking into a rear gear swap . i did some research ( im mostly self taught because my dad is at work) and im still fuzzy. i get there are different series carrier and gears for a GM 12 bolt ( 2,3,4) if im not mistaken. i get i can get thicker gears and ring gear spacers. here is where it gets tricky. i want 3.73's in it (4 series) and i have 2.73's (series 2) in it now with an LSD. but on the factory sticker in the glove box(with all the parts list and stuff) it says it came with 3.08's (series 3). sorry for the jumble of info im just trying to give you guys best description. so my question is what are my options for putting 3.73's in. what carrier is installed? series 2 since the gears are? im confused and i dont want to go down the wrong path since these things arent very cheap. thanks guys.
Caleb is offline   Reply With Quote
Old 07-31-2014, 10:55 PM   #2
geezer#99
geezer#99's Avatar
Re: Rear gear change question
Pull the cover off first and see exactly what gears you have and then go from there!
Old 07-31-2014, 11:41 PM   #3
Caleb
Caleb's Avatar
i have. when i replaced my rear axle seals i saw they were 2.73's. Thats where im stuck. is it series 2 carrier? 3? is it possible to put 3.73's in a series 2. should i just search car-part.com and find a whole rear end?
