Old 08-01-2014, 02:32 PM   #1
woodsrat
Transfer case help
1984 GMC 1 ton 4x4 transfer case stuck in low range or neutral.
Can move the low and neutral pin with a pry bar to chance them but Can't get the lever to go to 2 wheel or 4 high.
woodsrat is offline   Reply With Quote
Old 08-02-2014, 05:35 AM   #2
andrewmp6
Re: Transfer case help
Do you know what t case you have in it ?
andrewmp6 is offline   Reply With Quote
Old 08-03-2014, 03:01 AM   #3
farmall
farmall's Avatar
Check out the NP205 rebuild thread on the front page of the 4X4 tech section.
I just rebuilt mine with the help of this info. It shows the shift shafts and detent balls.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 08-04-2014, 02:17 PM   #4
woodsrat
I looked for a tag on it but can't find it, So not sure but I do know that the lever only goes straight ahead or back and nothing sideways as some are.
Old 08-04-2014, 02:19 PM   #5
woodsrat
I will see it I can find it, Thanks
Old 08-04-2014, 03:49 PM   #6
woodsrat
Just looked at the NP205 thread, What a great job on that!
Now I am wondering if maybe the detent balls are out of place or if it has a broken spring in the one shaft that won't move.
My linkage is defiantly different than that one in the pics.
Old 09-26-2014, 04:52 PM   #7
woodsrat
Still looking for some help and don't want to keep high jacking others threads!
Old 09-26-2014, 05:26 PM   #8
rich weyand
rich weyand's Avatar
First thing is to figure out which one you have.
Can you post a pic of the rear side of the transfer case?
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 09-26-2014, 06:09 PM   #9
jjzepplin
jjzepplin's Avatar
Ok I found your thread. So waiting on those pics.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-27-2014, 03:17 AM   #10
andrewmp6
It should be a np205 but you never know with a older truck people swap things out for odd reasons.Like said take some pictures of the t case one of us can id it for you.
Old 09-29-2014, 01:40 PM   #11
woodsrat
I Removed lower detent (Gage)spring and ball and still can't move the rod in any direction.
This is the lower rod that is stuck and appears to be all the way out.
I can move the top rod in and out one place and that makes the truck either in low range or neutral but I can't get it back into gear (with shifter) with out crawling under it and moving it with a pry bar.
Not sure if this rod should move more than that.
How do I post pic or who can I sent them to that will post them for me.
Old 09-29-2014, 06:33 PM   #12
79Betty
79Betty's Avatar
Still waitin on info on which tcase u have... Assuming a 205 hit it with a hammer. Worked for me when i dropped mine out of a cherry picker 6' up
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-29-2014, 09:09 PM   #13
jjzepplin
jjzepplin's Avatar
Are you trying to shift without moving the driveshafts? You have to align the gears somehow and in a real situation the truck would be moving the gears a bit with the trans being in neutral it still moves and releases some tension on the gears and some movement is needed.
And as stated above we need pics !!!
No more posts from myself til pics are taken and posted! LOL
My bad! look for the "go advanced" link on the lower right of your post. Click and look for the paper clip in the choices. Click and browse find your pic.Either saved to your computer or from your camera card inserted in your computer. Make sense?
Old 09-29-2014, 09:38 PM   #14
farmall
farmall's Avatar
https://www.google.com/search?q=np+2...ed=0CAcQ_AUoAg
Does this look familiar?
Old 09-30-2014, 12:09 PM   #15
woodsrat
Lets see if the pics work!
1: Rear of transfer case.
2: PTO side of transfer case.
3: Front of transfer case with linkage set-up.
4: Inside sticks.
5: Shift pattern on stick.
Old 09-30-2014, 07:08 PM   #16
jjzepplin
jjzepplin's Avatar
Good job! Man you are a pro at pics already! That looks to be a NP205. I may have missed it but what is the PTO for?
Make sure it is disengaged before trying to shift the case.
Your case linkage seems to be in order and correct.
I am thinking your issue may be something to do with the PTO.
I would clean all that junk off there(first) and see if it isn't just stuck from rust or something.
Old 09-30-2014, 08:42 PM   #17
jbclassix
Junk Yartist
jbclassix's Avatar
I believe your problem is the PTO. Pull it!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-01-2014, 09:48 AM   #18
woodsrat
jjzepplin, Thanks for helping me with the pics and everything else so far!
PTO is for the dump box.
Dump box will go up if PTO is engaged and truck is moving and if not moving the truck you have to put everything into neutral to dump it.
Does this make sense to everyone?
If I pull the PTO is anything going to fall apart?
Old 10-01-2014, 05:40 PM   #19
jjzepplin
jjzepplin's Avatar
Some fluid may come out but every PTO I've ever taken out no parts fell out. Simple gear to gear type install.
Clean that thing off first!
