Old 08-01-2014, 03:45 PM   #1
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
Project Cappacino.
Well figure I better start a build thread. I could use some guidence on how to post pics though.
Lets start by sayiong my truck is a 72 LWB Custion deluxe Highlander edition Med olive and white. I am in the home stretch of a 2yr frame off and will start posting pics shortly one I figure out how.
Kevin
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 08-01-2014, 03:55 PM   #2
GobbleStalker
GobbleStalker Calls
Re: Project Cappacino.
Lets try this a few pics of teardown to frame.
Stay Tuned!
Old 08-01-2014, 03:58 PM   #3
GobbleStalker
GobbleStalker Calls
Bare chassis teardown then starts.
Stay Tuned!
Old 08-01-2014, 04:01 PM   #4
GobbleStalker
GobbleStalker Calls
Sandblasting and painting of the chassis.
Stay Tuned!
Old 08-01-2014, 04:24 PM   #5
mcbassin
Still Learning
mcbassin's Avatar
Looks like you off to a solid start. I have always used photobucket to store my photos then copy and paste links here. Looking forward to following along.
mcbassin is offline   Reply With Quote
Old 08-02-2014, 09:32 PM   #6
Hardesty454
Hardesty454's Avatar
Beautiful start. Can't wait to see more.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 08-05-2014, 08:18 AM   #7
GobbleStalker
GobbleStalker Calls
Well front end put together now on to the rear end.
Stay Tuned!
Old 08-05-2014, 11:21 AM   #8
GobbleStalker
GobbleStalker Calls
Rear suspension reistalled and upgraded all but the swaybar.
Stay Tuned!
Old 08-05-2014, 11:24 AM   #9
GobbleStalker
GobbleStalker Calls
Engine off for rebuild. now a fresh 355CU. approx 400hp.
Stay Tuned!
Old 08-05-2014, 11:39 AM   #10
mikeleeshields
mikeleeshields's Avatar
Man you work quick. Looks good.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 08-05-2014, 11:57 AM   #11
GobbleStalker
GobbleStalker Calls
LOL no I have been building this truck for 2 years just getting to post the pics now. Truck should be in paint before end of August.
Kevin
Stay Tuned!
Old 08-05-2014, 11:59 AM   #12
GobbleStalker
GobbleStalker Calls
The turbo 350 completley rebuilt and mated to the engine. Then dropped into the chassis.
Stay Tuned!
Old 08-06-2014, 10:49 AM   #13
GobbleStalker
GobbleStalker Calls
Installing my original uncut dash into my new donor cab.
Stay Tuned!
Old 08-06-2014, 10:53 AM   #14
GobbleStalker
GobbleStalker Calls
Now cab panel replacemment and vintage air plates welding begins. Pounding out dents and getting the cab ready for primer. Future owner of the truck inspecting the work.
Stay Tuned!
Old 08-06-2014, 10:58 AM   #15
GobbleStalker
GobbleStalker Calls
Cab is now in primer and ready for block sanding before painting the firewall and floor.
Stay Tuned!
Old 08-06-2014, 11:03 AM   #16
mcbassin
Still Learning
mcbassin's Avatar
That chassis and engine are works of art! Excellent progress on the cab too.
Old 08-07-2014, 10:58 AM   #17
GobbleStalker
GobbleStalker Calls
Laid paint on the firewall and bottom of cab. The truck will be this Sunset Bronze Mica and Pearl White when complete.
Stay Tuned!
Old 08-07-2014, 11:00 AM   #18
GobbleStalker
GobbleStalker Calls
Doors have been fitted now time ot strip paint fill holes and get ready for primer.
Stay Tuned!
Old 08-07-2014, 11:05 AM   #19
mcbassin
Still Learning
mcbassin's Avatar
Paint looks incredible!
Old 08-07-2014, 01:02 PM   #20
71' Custom
71' Custom's Avatar
Wow! Very nice build! Sub'd
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Project: Under Pressure II
http://www.67-72chevytrucks.com/vboa...d.php?t=559720
71' Custom is offline   Reply With Quote
Old 08-07-2014, 02:09 PM   #21
GobbleStalker
GobbleStalker Calls
Not the best picture but the new posi pumpkin with 3:42 gears gets stuffed into the housing.
Stay Tuned!
Old 08-07-2014, 02:46 PM   #22
Xeen
Xeen's Avatar
Nice job on the old girl.
Have you been able to find headers that will clear the CPP tubular engine stands?
If you haven't started looking into it yet trust me you don't even want to mess with it I have a better solution.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-07-2014, 03:19 PM   #23
GobbleStalker
GobbleStalker Calls
Yes I am using Sanderson shorties. They fit great.
Stay Tuned!
Old 08-08-2014, 11:22 AM   #24
GobbleStalker
GobbleStalker Calls
Now that the outside firewall and floor are painted the cab meets the frame and the doors get fitted back on.
Stay Tuned!
Old 08-08-2014, 11:27 AM   #25
GobbleStalker
GobbleStalker Calls
The truck was a steel floor but I am now converting it to a wood floor bed. Did a mock up bolting of the box and then give it a test fit. Starting to look like a truck again after almost 2 years.
Stay Tuned!
