Old 08-07-2003, 02:45 PM   #1
blhansen
disc brake question
I have a co-worker that would like to convert his 67 chevy 2WD 3/4 ton pick up to a disc brake setup. He would like to make sure what he can use for a donor truck. Specific years would be great. I'm pretty sure this is an obvious question but i want to triple check. Thanks!
blhansen is offline   Reply With Quote
Old 08-07-2003, 09:42 PM   #2
crazy longhorn
Fabricate till you "puke"
this will get you started.... http://67-72chevytrucks.com/vboard/s...threadid=13692 Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
