08-01-2014, 07:30 PM | #1 |
Rally's on a 64
Came across a set of rally's for $100 with nuts and beauty rings. Looks like they came off a later model truck due to the center caps but I'm not sure. I'm collecting parts for my 64 right now, my question is if I go to drop spindles with the 5 lug conversion will these fit? They are 5 lug, 8" wide and had 4" bs...
08-01-2014, 07:37 PM | #2 |
Re: Rally's on a 64
if they are the 4x4 style wheels they will fit. most newer rims will fit
08-01-2014, 08:03 PM | #3 |
Re: Rally's on a 64
If they are later model rally's they will fit. 4x4 rally's are 6 lug.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-02-2014, 09:31 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Rally's on a 64
You said the rallyes are 5 lug, they will fit if you do a 73-87 disc swap and swap your rear for 5 lug also. You can just have your Current axles welded/drilled or mosier has replacement axles with 5 lug.
I have a 71/72 front and rear, 2.5" drop spindles, 2" drop springs and rear bags and I run 7"/8" on my 65. I like the way they look.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-02-2014, 09:33 AM | #5 |
Re: Rally's on a 64
The bottom picture ^^^^^ is before the spindles.
The top pix has my oldest daughter. She and the truck "grew up" together ) I got the truck when she was 2 years old for my DD. She has always loved helping me work on the truck ( CLyde).
08-02-2014, 05:15 PM | #6 |
Re: Rally's on a 64
BTW, also make sure the "5 lug conversion" isn't something that uses car stuff with a 5 on 4.75" pattern.
