Old 08-01-2014, 07:47 PM   #1
NC67Chev
NC67Chev's Avatar
Ball joint question
I decided to go ahead and replace ball joints while I was installing disc brakes. When I put the spindle one the passenger side, I notice that it seated really deep. I just decided to move forward and with the drivers side and come back and torque everything later. When I torqued it (I followed the Moog instructions of 55 ft/lbs for the upper) it seated so deep that I had to use a washer in order to get the cotter pin to mesh with the castle nut. The other new upper seemed to seat correctly. I knew something wasn't right, so I decided to take it apart and look at it this evening. As soon as I unbolted it, the ball joint separated, so it was basically just sitting in there. I tested one of the old ones and it seated just fine. Thoughts? Wrong ball joint?
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 08-01-2014, 10:22 PM   #2
spatz
Re: Ball joint question
Sounds and looks like the new one isn't correct.
spatz is offline   Reply With Quote
Old 08-01-2014, 10:24 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
what year spindle?
what year ball joint?
Keith
Convert to disc brakes.
Old 08-02-2014, 07:47 AM   #4
NC67Chev
NC67Chev's Avatar
The ball joints are Moog K6024 63 - 70 and the spindles are 63 - 70 McGaughy's.
Old 08-02-2014, 07:51 AM   #5
NC67Chev
NC67Chev's Avatar
I don't have a caliper to measure with (that's what I was unsuccessfully trying to use the crescent wrench for), but to me it looks like the taper on the new one is slightly different.
Old 08-02-2014, 07:59 AM   #6
lolife99
lolife99's Avatar
Ball joints and spindles have to match.
Keith
Old 08-02-2014, 11:10 AM   #7
NC67Chev
NC67Chev's Avatar
They do match....both are 63 - 70. I guess I have to assume that either this new ball joint was in the wrong package or there was something wrong with it.
Old 08-03-2014, 07:20 AM   #8
19Chevy67C10
19Chevy67C10's Avatar
I had a chance to look at all my new but old boxes of when I tore down my k-member and replaced all the parts.I used the same k6024 moog problem solver upper ball joints with those same Mcgauhys spindles and it all worked out.I believe you either have later model McGaughy's spindles which require the larger upper and lower drift ball joints, the 63-70's are a smaller drift/pin ball joint than the later ones used in 70-up...The upper ball joints you have pictured appear to be different in size...
Kev's-C-10
19Chevy67C10 is offline   Reply With Quote
