Old 08-02-2014, 10:01 AM   #1
blazer2007
My full exhaust the hard way
Got tired of the noise of short exhaust and finally one got torn off by a curb ,so I knew I had to do some rust repair on the floor and after digging through the rust I decided to replace the whole floor[,how hard could that be] a new floor was too much money .Got the floor torn out and decided to do the exhaust.Got some pipe bent the way I thought it should be and welded them together,just have to put on the turnouts and done.
blazer2007 is offline   Reply With Quote
Old 08-02-2014, 10:09 AM   #2
blazer2007
Re: My full exhaust the hard way
I used .063 1 in. sq. tubing and using 14 gauge for the floor.Now I have to try and make some wheel tubs
Old 08-02-2014, 10:44 AM   #3
blazer2007
I still have to put in a couple more cross braces
Old 08-03-2014, 01:56 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
How far up did you move the floor?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-03-2014, 06:34 PM   #5
dragonball98312
dragonball98312's Avatar
This is what I plan to do when I bag my blazer. Looking good!
dragonball98312 is offline   Reply With Quote
Old 08-03-2014, 06:36 PM   #6
dragonball98312
Also is that bench using some sort of stock mounting hardware or homemade?
Old 08-04-2014, 09:58 AM   #7
blazer2007
It,s up 2 inchs
Old 08-04-2014, 10:04 AM   #8
blazer2007
I,m using a bench seat,I didn,t want the rear seat but wanted room for 3 if needed.I made the brackets for it,was quite easy.I like the old look ,didn,t want any fancy buckets or bench seats
Old 08-04-2014, 10:28 AM   #9
blazer2007
Here is a pic of the seat,I,ll be getting rid of the auto meters and use stock dash and column shift
