71 gas pedal in a 69 issues
I've come to a minor issue with my 71 gas pedal install in my 69, the throttle linkage that goes to the pedal rod the throttle barrel nut has nothing to hold it to the rod. Now I know they well barrel nut Collars, anyone have a solution to this ?
If need pics I'll post later on. |
Its a Truck Thing......
Re: 71 gas pedal in a 69 issues
My burb was converted. Post some pics and ill show you what I did to mine.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
What goes on the barrel nut of cable to hold to the rod |
Not 100% what you're asking but that plastic but that I see against the firewall should be holding the cable inside the pedal rod slot. The throttle cable should have a square shape plastic part that snaps into the firewall.
I do think you're gonna have to trim a little notch in the middle of that rod support bracket in order for the pedal to swivel back and forth. |
Look at the very end of the pedal rod at the top where there's a hole for the cable, on the end of the cable is a barrel nut, the hole for the pedal rod is too big to hold that cable inbetween that hole. What do I put on the end of the cable to make it so it stays, I hope that's a little better explanation. Everything works Except cable to pedal rod
Moderator
![]() Join Date: May 2007
You are missing the plastic piece that retains the cable in the pedal. I will post a pic later if nobody does before me.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#7 | |
![]() Join Date: May 2013
Tom 71 K2500 71 K5 Jimmy |
#8 | |
This I was thinking it was just pushed to the firewall didn't notice he little medal end in the bracket hole. |
Do the sell this as a replacement part, been looking all over, not finding that plastic piece anywhere. If they don't sell it i guess I gotta wait til a 71-72 truck part out.
look at this link and you can see the little plastic piece you need, could probably find one at a salvage yard on a chevy in the 70's.
http://www.ebay.com/itm/71-72-chevy-...a5bef2&vxp=mtr |
For what it's worth, I used a 77 on my 68, it's identical until sometime in the 80s I believe.
#12 | |
Accelerator cable retainer 71-74 truck #89-753
#13 |
Wow thanks a lot, that's a huge help!
