restoration specs
Has anybody documented or is there a book (highly doubt the book) a 69-72 k5 blazer restoration regarding original finishes , fasteners etc??? I like originality and when I restore ky 72 I would like it to be as original. Thanks for any information
SKINNY TIRES RULE!
Re: restoration specs
There is the factory assembly manual available, although it doesn't list every detail.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Does it list finishes in it?
SKINNY TIRES RULE!
Not that I remember.
Carpe manana
![]() ![]() Join Date: Dec 2010
Here's a thread that hits on finish for some bolts/screws: http://67-72chevytrucks.com/vboard/s...d.php?t=624189
One finish detail to consider is the paint atop the dash between the windshield and dash pad: this was painted to match the pad and has a flat finish from GM to reduce glare. Door strikers were parkerized (phosphate coated) not painted and door latches were natural finish not painted. Parkerize the hood hinges - the resultant finish and function are excellent. I'd also parkerize the body bolts and engine brackets so they can be torqued on without the finish (i.e., paint) flaking off. Here are examples: http://67-72chevytrucks.com/vboard/s...4&postcount=96 and http://67-72chevytrucks.com/vboard/s...&postcount=114
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thanks Pete, thats the info I was looking for. I suppose I should buy an assembly manual as well. Do you have a picture of your engine bay? In particular Im looking for passenger side valve cover view....thanks, Brian
Another thing, werent you looking for a rollbar, I saw a 69-72 k5 being parted out in northwest Montana on Craigslist and he had a rollbar.
#8 | |
Carpe manana
Thanks Brian! I saw that add. Another member set me up with a roll bar but I appreciate your help. Pete
I did look at your k20....nice by the way! On the blazers wasnt the oil fill cap on the drivers side rear valve cover or was there another on the pass front valve cover. All my engines are different, looking for the correct location.
Carpe manana
Thanks! Do you have A/C? If so, you should have the oil fill tube that plugs into the driver side valve cover in the rear.
No ac, no power brakes either. What goes in the drivers side rear hole then?
Carpe manana
A plug I believe - check the survivor engine thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=549556
