Old 08-02-2014, 05:51 PM   #1
Dads79GMC
Dads79GMC's Avatar
What's Wrong With This Picture?
Is it just me or my new McGaughy's 2.5 Drop Spindles? Spent all day today putting together my new front end components, when installing the caliper on the right side (last bolt), the top caliper bolt would not push all the way through, even rubs against the rotor. Should I take it apart and return, or take the caliper and rotor back off and give that area a little smack to gain clearance????? I'm hosed!! Probably should just give McGaughy's a call!
Left side went smooth though!!!
Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 08-02-2014, 11:23 PM   #2
mattcrp1
mattcrp1's Avatar
Re: What's Wrong With This Picture?
I had similar experience with another brand of dropped spindles and had to "dress" the spindles and calipers with a file to make the bolts push in easily. I haven't driven my truck yet but I am hoping my calipers "float" correctly. I found that the area were the caliper sat was not allowing enough movement and causing misalignment of the caliper bolts on mine.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 08-03-2014, 01:11 AM   #3
trixter99
I have no time for this
trixter99's Avatar
That's a huge misalignment I would send them back.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 08-03-2014, 03:11 AM   #4
Nin92
Nin92's Avatar
Looks like a defective spindle. Definitely contact them and get it resolved
Nin92 is offline   Reply With Quote
Old 08-03-2014, 07:13 AM   #5
Desert1957
Desert1957's Avatar
Mike
Did you specify 1" or 1 1/4" rotors before ordering?
Looks like a large rotor on a smaller spindle setup.
Desert
Desert1957 is offline   Reply With Quote
Old 08-03-2014, 09:25 AM   #6
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
I had the same issue with the same brand. It's not off as far as it looks. Some minor clearancing of the flat surface of the caliper bracket where the caliper slides corrected the issue. I never had any problems with the brakes as a result.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 08-03-2014, 09:47 AM   #7
Dads79GMC
Dads79GMC's Avatar
Desert
It's the correct spindle as far as I know. I specified 1.25 and the receipt indicates 1.25.
