Old 08-02-2014, 10:18 PM   #1
chewychevy67
what finish was on the smog manifold tubes from factory
Anyone know what finish was used from factory on the A.I.R. tubes that go on the exhaust manifolds. Plating, paint or other? Hopefully something that will stay on for longer than a week. I am going to have my manifolds ceramic coated. Rod.
chewychevy67 is offline   Reply With Quote
Old 08-02-2014, 10:32 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: what finish was on the smog manifold tubes from factory
Although I dumped all my stock Calif. '68 A.I.R. gear in a 50 gallon trash barrel at Cherry Point NC, back in 1974, I seem to recollect it was painted something close to a hi-temp Cast Iron Gray.
Old 08-02-2014, 11:17 PM   #3
chewychevy67
yeah I am going to de-vein the pump and block the tubes so that it looks the part but is inoperable.
Old 08-02-2014, 11:48 PM   #4
'68OrangeSunshine
Well it's your truck, Friend, but if it were my project, I'd dump 45 Lbs of No-Go gear, and those Lo-Perf A.I.R. rams horns, and ceramic coat some good headers.
Old 08-03-2014, 12:47 AM   #5
chewychevy67
I am rebuilding stock so no headers. Anyone confirm grey?
Old 01-08-2015, 10:25 AM   #6
chewychevy67
Ttt
Old 01-08-2015, 05:49 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
My recollection is cad plate, but that's from 40 years ago. Maybe check out Team Chevelle. Lots of restoration experts over there. http://www.chevelles.com/forums/
~Steven
Simi Valley, CA
Old 01-10-2015, 09:26 PM   #8
chewychevy67
I was hoping it would be something more resistant to heat. my plating guy says that cad will discolour first start up. Any plating out there that will last with the heat? Ill look into the car sites as well. Rod.
Old 08-20-2016, 11:18 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Rod found this thread in a search. Not sure it matters but I have a nos example here that is black.
Old 08-20-2016, 11:23 PM   #10
chewychevy67
Sweet I have not done anything with these yet. Painted? Plated? What sheen?
Old 08-21-2016, 11:23 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Painted. Has a slight sheen akin to that I'd expect on chassis black. Pic includes the GM parts label and indicates made in USA.
This part is correct for both the LH and RH manifolds on a 72 4wd application but may be correct for RH only on other applications. I have intact CA emissions on my finished 72 Blazer and it has same tubes (pipes GM called them) both sides.
Old 08-21-2016, 02:09 PM   #12
toms68cst
toms68cst's Avatar
Other than some cleaning, I left mine they way they were.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 08-21-2016, 03:07 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Also curious if you guys have differing part #s for the exhaust manifolds. My k5 has the heat stove blocking view of the part number. The set I picked up for my new build is composed of two RH manifolds (for 4wd application) that are drilled and believe are OEM. Guess I'm wondering I'd GM used two RH exhaust manifolds for 4wd trucks w CA emissions. Smog tubes are the same.
Old 08-21-2016, 06:44 PM   #14
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Well, here is my offering ...
I used to think they were silver cad plated.
But, over time I've learned otherwise.
Some come as painted black, years ago I recall seeing them silver cad.
But today I feel that they were either silver or yellow cad;
Then painted over black.
What seems to me happens,
That after installed on manifolds then ran and going thru the heat process,
the heat transfers across the plating with the paint and it appears to bond.
Over time, this bonding together creates its own brownish hue.
On my tubes, the paint seems thinned out with the bonding processes the heat does to them, and then allows the plating to bleed thru somewhat causing the look of that being a brownish hue.
That's the best I can determine of what the finish ends up looking like
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 08-22-2016, 08:54 PM   #15
fleetimus
fleetimus's Avatar
Ceramic coat them black or possibly tungsten
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 08-22-2016, 08:56 PM   #16
davepl
davepl's Avatar
Why? It takes about 1/10th of a horsepower, worst case, and merely injects air into the exhaust manifolds.
Best case it reduces emissions; worst case you never know it's there.
I'm not sure why people are so prone to remove this stuff (though I get the pump is big and ungainly, but in this case you're keeping it anyway). I think it's because it came along at the same time as net ratings, low compression, bad cams and everything else that started in the smog era. But A.I.R. pumps don't hurt performance or economy, so why not just run it in factory config?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-22-2016, 09:24 PM   #17
burb71
Active Member
I painted mine hi temp black, Im going for a stock resto also
burb71 is offline   Reply With Quote
Old 08-23-2016, 06:14 AM   #18
chewychevy67
When I got this motor the correct carb for the smog was gone. I know it has a different part # than the standard 4G carb. Now finding the correct 66-67 only smog carb is nearly Impossable. By 66 most all cars had Quadra jets so I can't use a car carb. 67 trucks were the only vehicles using 4G and smog in 66-67 is rare enough already. I kept the dizzy aside and changed it all to standard. I don't want to mess around with the engine when complete with a system that doesn't work properly because I don't have all the correct pieces. If I had them all I would make it work as it should.
Old 08-23-2016, 02:19 PM   #19
davepl
davepl's Avatar
Makes sense!
