Old 08-03-2014, 12:05 AM   #1
Turambar
Turambar's Avatar
79 GMC Sierra Driveshaft issues
I've searched the forum for this, and I am sure this has come up before. For the life of me, I cant find it.
I dropped my 79 with DJM Suspension parts. I used a flip kit in the back. Specifically in the instructions, it states the following:
"Note : Two piece drive shafts on most 1/2 ton trucks should be replaced
with one piece drive shafts. If you must retain your two piece drive shaft,
modify the carrier bearing frame support so it can be raised approximately
1-1/2” to correct drive line angle."
I have a two piece drives shaft in my 1/2 truck. For giggles, I put everything back together stock. It was pretty obvious that this would not work. So, I painstakingly removed the carrier bearing frame support and shortened it be 1.5 inches. The truck isn't in ready to be fired up yet, but looking at it I am worried that the shaft isn't perfectly straight. So... I'm kinda worried...
Has anyone else done this? I am also considering this part of the DJM instructions: "Two piece drive shafts on most 1/2 ton trucks should be replaced with one piece drive shafts."
Total noob here. Where would I get said "one piece" driveshaft that would fit my truck? The end of my transmission (th400) and my diff both have a spot for u-joints to bolt up. How would the one piece drive shaft hook up? Could I get what I need from a salvage yard? What would I even be hunting?
I can probably provide pics tomorrow, but any advice would be appreciated.
Turambar is offline   Reply With Quote
Old 08-03-2014, 08:06 AM   #2
cadillac_al
Re: 79 GMC Sierra Driveshaft issues
Most junkyards have piles of old driveshafts to pick from. It doesn't cost all that much to have one made either. I don't think the 2 piece is supposed to be in a straight line anyway. The first one is fairly straight back then the 2nd one goes downhill to the rear axle. Just my .02, I have no experience in lowering a truck.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 08-03-2014, 12:18 PM   #3
geezer#99
geezer#99's Avatar
Read these!!
Study hard!!
There will be a test!! LOL!!
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
http://www.drivetrain.com/parts_cata..._problems.html
Old 08-03-2014, 03:20 PM   #4
Just call me Sean
Just call me Sean's Avatar
In my experience, most junkyards bend every driveshaft the first time they pick up the vehicle with a forklift.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
