Old 08-03-2014, 11:45 AM   #1
Ricks1971
Ricks1971's Avatar
1967 C10 ebrake adjustment?
Does anyone have pics of where to adjust my ebrake. I just put new brakes and need to adjust the ebrake. thanks Rick
Ricks1971 is offline   Reply With Quote
Old 08-04-2014, 10:00 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 1967 C10 ebrake adjustment?
I see no one has responded. Here's an old pic of the cable assembly under my 68. If it's the same, you can tighten the nut on the adjustment link. On one of my trucks I used larger nuts as shims on the adjustment link to get some added tension.
If that's not the adjustment you're wanting, give us more info.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-04-2014, 10:04 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Here's a link that may help. It's a couple of years earlier but similar.
http://67-72chevytrucks.com/vboard/s...d.php?t=527022
06 Trailblazer
