Old 08-03-2014, 01:48 PM   #1
no1udknow
no1udknow's Avatar
square body booster in to a 68
hey guys, just procured the front suspension and brake system from a 85 c10 with 79k original miles. brake booster and MC look like they have less than that. I was wondering if anyone had pics on how they installed this system on their firewall?? I'm getting ready to do it and would love some ideas. thanks.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 08-03-2014, 10:57 PM   #2
no1udknow
no1udknow's Avatar
Re: square body booster in to a 68
noone? OK well I guess I'll be the first lol.... I was looking at the 67 parts truck in the driveway and it looks like I'll need to modify the lower portion of the mounting bracket to clear the steering column.
Built not bought!
Old 08-04-2014, 10:38 AM   #3
wreckedchevy
wreckedchevy's Avatar
I believe captainfab has an adapter plate you can buy that will allow you to bolt that booster to your firewall with out cutting. you will still have to modify your push rod though.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 08-04-2014, 10:49 AM   #4
wreckedchevy
here's some info on swapping the rest
http://67-72chevytrucks.com/vboard/s...+brake+install
Old 08-04-2014, 01:23 PM   #5
ericjon262
how about on a 70 model that already had the 4 bolt firewall? anyone know if the spread is the same?
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 08-04-2014, 03:13 PM   #6
wreckedchevy
as far as I know you still need captainfab's adapter or do your own fab work
Old 08-04-2014, 03:25 PM   #7
ericjon262
I saw a couple of pictures of a squarebody booster, and it looks as though they are angled off of the firewall whereas our boosters bolt square to the firewall...
Attached is a diagram with the distances between the booster firewall studs from my 1970 3/4 ton GMC.
Old 08-04-2014, 07:09 PM   #8
wreckedchevy
here's the adapter I mentioned earlier
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
Old 08-04-2014, 07:27 PM   #9
ericjon262
neat, but won't work with column shifters.
Old 08-04-2014, 07:59 PM   #10
frogsmakr
frogsmakr's Avatar
It'll go. You have to drill, and make up a pushrod as previously mentioned. I've done several.
67 C-10 shortwide
'06 Triumph Thruxton
'09 Harley 'Lectra Glide
'95 Z-71 two door Tahoe
frogsmakr is offline   Reply With Quote
