Old 08-03-2014, 05:55 PM   #1
Sp1200
(1994 4.3l v6 TBI) is LATE YEAR block & heads possible?
So I may need a new engine and am having a hard time finding a low mileage used engine at the bone yards.
I'm wondering if anyone knows if it is possible to use a newer engine & heads and swap over my 94 TBI intake setup?
I notice on the newer engines the AC and Alt is swapped over.
I dont want to lose my AC charge. Nor do I want to change the wire harness.
Wondering if a possible top end swap and drop in is possible.
I'm not looking to get a V8, just want to get a low milage V6.
Thanks for any advice guys.
Sp1200 is offline   Reply With Quote
Old 08-03-2014, 06:17 PM   #2
casper71
Re: (1994 4.3l v6 TBI) is LATE YEAR block & heads possible?
You should have no problem using a later model engine with the vortec heads. you will need to swap you accessory brackets to the new engine.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 08-03-2014, 06:23 PM   #3
Sp1200
Ohh wow. So even the 96 and later ones with the plastic upper intake will work?
I thought the MAP Manifold Air Pressure was different.
