Old 08-03-2014, 10:11 PM   #1
JBX66
JBX66's Avatar
Brake light problems
My battery keeps getting drained because the brake lights stay on when the lights are off. I'll check the grounds again because that is 90% of the electrical demons that drive me nuts. However, I put new grounds on both sides on the frame a few months ago. Any ideas?
White 1966 C10 LWB Fleetside
1983 Mercruiser Marine 305 V8/Chevelle 4spd
"Ellen of Truck"
JBX66 is offline   Reply With Quote
Old 08-03-2014, 10:18 PM   #2
jtrichard
Re: Brake light problems
check the brake light switch above the pedal
jtrichard is offline   Reply With Quote
Old 08-03-2014, 11:50 PM   #3
rickywideglide
rickywideglide's Avatar
determine if its brake or running lights, had some issues with mine inside turn signal switch,the contacts inside might need to be tweeked
rickywideglide is offline   Reply With Quote
Old 08-04-2014, 03:39 AM   #4
Woogeroo
Wink Re: Brake light problems
x2.
I have had this problem more than once on my '65 C10.
The brake pedal switch gets a little loose or worn... it has a spring inside that always puts tension against the top of the brake pedal arm, so when you push the brake pedal down, the arm swings away from the brake pedal switch, the little peg/cylinder extends out, activating the switch and brake lights come on(if everything is wired up correctly).
It can be a little aggravating to adjust the first time you mess with it. If you have to take the wires loose from the brake pedal switch, they just slide right off of the end.
Good luck,
-W
Woogeroo is offline   Reply With Quote
Old 08-04-2014, 06:03 AM   #5
tazattitude
tazattitude's Avatar
Check first to make sure your brake pedal is not getting stuck. Pull back on it a little to see if it moves.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
