08-03-2014, 11:17 PM | #1 |
Overdrive
I spotted this at a Pick-n-Pull in SLC. I was wondering if it would be worth pulling out of the truck. I don't have a use for it myself. The picture is terrible I know. It is in a 69-70 Chevrolet 1 ton.
Paul |
08-03-2014, 11:25 PM | #2 |
Re: Overdrive
I guess it would depend on how much you'd have to pay, and how much you could sell it for later.
btw, I need to head to SLC tomorrow to find a drive shaft. Which pick-a-parts are worth stopping at? The only one I know of is A-1 on 2100 S.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
08-03-2014, 11:27 PM | #3 |
Re: Overdrive
What is it? An NV4500?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-03-2014, 11:36 PM | #4 |
Re: Overdrive
The price for an overdrive unit on their web site is $35.99. This one is at the Tear-A-Part on Redwood Road. Good luck on the drive shaft. I have yet to see one that has not been destroyed by the loader.
08-03-2014, 11:40 PM | #5 |
Re: Overdrive
08-04-2014, 01:18 AM | #6 |
Re: Overdrive
The only one currently is the Ranger overdrive built by Advance Adapters. May be an older version
08-04-2014, 09:02 AM | #7 |
Re: Overdrive
Paul,
I would pick that in a heartbeat. Wish it was in my back yard, I have plans to add one in the future. I agree it looks like an Advance Adaptor. Good luck, Bruce |
08-04-2014, 09:22 AM | #8 |
Re: Overdrive
Info on that splitter!
http://www.advanceadapters.com/downl...Overdrive0.pdf |
08-04-2014, 09:43 AM | #9 | |
Re: Overdrive
http://www.advanceadapters.com/categ...lete-units/91/
08-04-2014, 04:38 PM | #10 |
Re: Overdrive
Thanks for the replies I will go and get it tomorrow,if it is still there.
08-05-2014, 11:11 PM | #11 |
Re: Overdrive
More pictures
08-06-2014, 09:43 AM | #12 |
Re: Overdrive
Nice score at the part yard! Did you snag the shifter and the shift boot? Looks like a period correct advance adaptor. Can you confirm it is an overdrive. It looks cast iron the current available ones are aluminium. Good luck with futrue part hunting, Bruce
08-06-2014, 07:42 PM | #13 |
Re: Overdrive
In my best zombie voice.... IIIIII WWWWAAAANNNNNTTTT TTTTTHHHHAAAATTTT!!!!!! :-)
1990 Suburban Silverado 350, SM465 and 35" tires |
08-06-2014, 08:55 PM | #14 |
Re: Overdrive
You know what's weird? Just skimming through the photos I started to smell old grease and wrecking yard smells. The brain is funny.
Other than one down at the Oregon border I've never found a decent (or any) yard that carries anything useful around Seattle. If someone knows of a yard in the area that's not a 4 hour drive and has trucks, please let me know!
08-06-2014, 09:43 PM | #15 | |
Member #1049
Re: Overdrive
Also I would check with Binford Wrecking in Auburn. |
08-06-2014, 10:12 PM | #16 |
Re: Overdrive
That's a good point.... The same company makes an underdrive version as well... It was a 1 ton... Could be an under drive unit.
12-16-2014, 09:36 PM | #17 |
Re: Overdrive
I know this is an older thread, but I couldn't help but respond I'm putting in the new version in my build. It is the overdrive setup. I can't wait to get it all done with 3 sticks sticking through the floorboard.
12-17-2014, 10:53 AM | #18 |
Re: Overdrive
MIke,
Paul was kind enough to pull,package and send this to me. Alright, we did agree on a fair price. I have not installed it yet. I had a fatal cam lobe failure despite break-in and good oil. I can not prove but I believe it was improperly hardened by comp cams. I have a Rockwell T-221 case. So the case shifter is on the drivers side of the tranny. I have not quite figured out the right solution. Definately going to have to move the case shifter forward. What set-up do you have? I assume you will have to move the cross member and shorten/lengthen the driveshafts. Bruce |
12-17-2014, 11:44 AM | #19 |
Re: Overdrive
Bruce,
I also have the T-221 tcase in mine. My entire unit adds 7-1/2" to the length, so I ended up moving my engine forward 2" and the rear cross member back 5-1/2". For the tcase shifter, I built a plate for the two mounting holes on the passenger side of the transmission, and I'm in the process of building a linkage to connect that to the existing lever on the tcase. Overall, this was a fairly easy installation, except for the troubles with relocating my z bar for the mechanical clutch assembly that I still plan on running. I have some pics of my setup in my build thread that may give you some ideas. |
