08-03-2014, 11:24 PM | #1 |
Active Member
71 4x4 3/4 ton 6 lug???
Hi. I'm looking at a 71 4X4 and it has 6 lugs, shouldn't it have 8?? Vin info below...
KE241S621291 K = 4WD E = V8 2 = 3/4 ton 4 = Pickup 1 = 71 (year) S = St Louis I appreciate any help..
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. |
08-03-2014, 11:28 PM | #2 |
Re: 71 4x4 3/4 ton 6 lug???
perhaps a chassis swap. check the frame vin stamping. yes, should be 8 lug on a KE2
OR... where are you getting the VIN from? SPID? VIN plate on door sill? If SPID, could be a glovebox swap. Or perhaps if SPID and metal tag match, a cab swap. |
08-03-2014, 11:48 PM | #3 | |
Active Member
08-03-2014, 11:59 PM | #4 |
20' Daredevil (Ret)
Yeah, something's been swapped. K10s had 6 lugs, K20s had 8 lugs.
08-04-2014, 09:52 AM | #5 |
All C/K20s were 8-lug. My guess is axles swapped. Next guess would be the title goes by the VIN-plate on the K/20 cab that was swapped onto the K/10.
