Old 08-04-2014, 09:05 AM   #1
Jimal
Jimal's Avatar
Brake drums for K-10s
After tinkering for a bit I was able to get the brakes on my '65 K-10 to work well enough to be able to move it under its own power into my garage. Upon disassembly however, I quickly discovered that the brakes are well and properly borked.
At least the rears anyway. I'm assuming the fronts are probably as bad so I'm doing all four corners. Down to my local NAPA, where I was able to order everything I needed to do a comprehensive brake job, with the exception of drums. The only drums listed were rears for trucks with coil springs (C-10). I had pretty much the same luck on Rock Auto and other, similar sites. Through the rust we found a part number that looks like it could be "3854776", but that doesn't cross to anything.
At this juncture I'm not looking to do a disc brake upgrade if I don't have to. What have you guys used for drums?
Jimal is offline   Reply With Quote
Old 08-04-2014, 09:08 AM   #2
MitchFloyd
MitchFloyd's Avatar
Re: Brake drums for K-10s
You can order drums from RockAuto.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 08-04-2014, 09:42 AM   #3
Jimal
Jimal's Avatar
Hmm... Perhaps I picked the wrong engine option, because I when I looked on Saturday, and the counter guy at NAPA did as well, the listings were for coil spring truck only. That was both on Rock Auto and napaonline. They appear to be rather standard GM/Bendix brakes.
Old 08-04-2014, 10:05 AM   #4
PGSigns
PGSigns's Avatar
I think on that 12 bolt all the brake hardware is the same C10 or K10. Did a quick check on Orielly's web site and they have them and show fit both.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-04-2014, 11:12 AM   #5
Jimal
Jimal's Avatar
Jimmy
We'll find out tomorrow. The guy at NAPA ordered up a pair of what he thought were correct based on what I brought into him. I don't know if I should be surprised that the listing are so vague.
Old 08-04-2014, 11:49 AM   #6
1963c-10
1963c-10's Avatar
Our local Napa / Autozone doesn't even show a 12 bolt rear end in a 1st gen c-10. They list the HO 32 and Dana only.......Its no use trying to explain it to them either.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-04-2014, 12:00 PM   #7
Jimal
Jimal's Avatar
My guy seems to be pretty good. We did find what looked like a number on one of the old drums, but we couldn't make any iteration of that number cross with an existing part number.
Old 08-04-2014, 12:55 PM   #8
padresag
if I can remember correctly the frt drums on a 4 x 4 are the same as the rears
ron
padresag is offline   Reply With Quote
Old 08-04-2014, 02:44 PM   #9
jtrichard
You might want to check out this thread .....we found a solution to his drum problem maybe the same drums you need http://67-72chevytrucks.com/vboard/s...d.php?t=614719 read all 3 pages the answer is on page 3
jtrichard is offline   Reply With Quote
Old 08-04-2014, 03:44 PM   #10
Jimal
Jimal's Avatar
Interesting. This might be my backup plan if what the guy at NAPA ordered doesn't pan out.
Old 08-05-2014, 12:06 AM   #11
Captainfab
60-66 Nut
That was about finding drums for the 6 lug Dana 44. The OP's '65 K10 should have the truck 12 bolt
The 6 lug drums for a truck 12 bolt should all be interchangeable up thru the mid to late 70's. You just need the drums for the 2" wide shoes. There was an option for 2-3/4" wide shoes. You could upgrade to those on the rear, but you would have to change the backing plate.
Old 08-05-2014, 12:53 PM   #12
61K10
61K10's Avatar
my drums on my 61k10 are all the same. they were just replaced when i bought the tk, so i don't know where they came from. they do have #'s on them. LMC lists 2wd the same as 4wd drums.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-05-2014, 03:21 PM   #13
Jimal
Jimal's Avatar
How the heck did I miss those? I ordered wheel cylinders from that exact page. Now I definitely have a backup plan if the drum from NAPA don't work. Thanks.
Old 08-05-2014, 03:29 PM   #14
padresag
believe that this was mentioned earlier
ron
Old 08-09-2014, 11:40 AM   #15
Jimal
Jimal's Avatar
Success! You can add NAPA P/N 440-1071 to the list of drums that work.
With the exception of some minor plumbing the rear brakes are done. Onto the fronts; I'll get them rebuilt and ready for the second pair of drums, coming this afternoon.
