Throttle cable bracket
Where would be a good place to find out if a Throttle Cable Bracket was made? Specifically for a Q-jet carb 1982 and up pickup style for a 700R4 transmission?
Re: Throttle cable bracket
I've used Edelbrock 8036 bracket kit. But may need throttle arm corrector - available from TV made easy. The EDL kit is designed to work with Gen 1 intakes, but some trimming of the tabs maybe required with certain aftermarket intakes... Alternatively get a complete kit from http://www.tvmadeez.com/
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
I an looking for the original style GM Bracket if it is available. I have an after market bracket now that causes more problems than it helps.
Junk yard, any V-8 700R4 truck 1982-1986.
1987 2 ton ![]() 1982 250/TH350 beater in progressDad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrappingPlus a mess o' tractors |
| Bookmarks |
