Old 08-04-2014, 04:57 PM   #1
Mthumphrey
Mthumphrey's Avatar
66 License Plate Light Wiring
Does anyone know where I can get a replacement light housing/wire for the license plate bracket? I have seen (and accidentally purchased) one for a 61. I have also found the entire bracket with light/ wire included, but I can't find just the wire and bulb holder. Ideas?
Thanks!
Michael
Mthumphrey is offline   Reply With Quote
Old 08-04-2014, 09:10 PM   #2
Woogeroo
Re: 66 License Plate Light Wiring
The 60-66 FAQ Index.
Section 2C
Parts Sources - information
-W
Woogeroo is offline   Reply With Quote
Old 08-04-2014, 09:38 PM   #3
AcampoDave
AcampoDave's Avatar
I went to the parts store and bought a prewired pigtail 12 volt bulb (kinda like what you see in aftermarket guages) then I gutted the old socket from my lens assembly, made a rubber gasket for the base of it, and sealed up the hole in the gasket where I pushed the wires thru it. I then just replaced the lens assembly on the bracket with my home made gasket sandwiched between and wired it up to hot and ground. I also drilled a drainage hole in the bracket for good measure
AcampoDave is offline   Reply With Quote
Old 08-05-2014, 01:30 AM   #4
Kenfuzed
Kenfuzed's Avatar
Section 2C
-W
The links in that part of the index need fixing. Link on that page results in:
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 55
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 107
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 111
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 119
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 130
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 134
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 142
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 211
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/init.php on line 389
Deprecated: Assigning the return value of new by reference is deprecated in /home/admin69/public_html/vboard/includes/class_core.php on line 2552
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 08-05-2014, 04:48 AM   #5
Woogeroo
That's the forum itself... it's having that issue all over, in different areas.
All I can do is edit the actual links... scroll down to visit the 60-66 FAQ Index.
If you'd care to, please let the folks who run this joint know about the issue in the Site Feedback & Announcements area.
-W
Old 08-05-2014, 10:17 AM   #6
Mthumphrey
Mthumphrey's Avatar
Thanks guys!!! Appreciate it...
