08-04-2014, 06:49 PM | #1 |
Starter issue Maybe?
I put a new starter on the blazer from NAPA. Now when I shift from Rev to Drive or put it in neutral the starter engages. It is a auto, column shift. I can turn the key to on and shift to neutral and start the truck with out touching the key. Any Ideas? I have traced all the wires from the starter and no bare spots. Could it be something it the column? Any advise/ideas welcome. Also it did not do this with the old starter.
08-04-2014, 07:31 PM | #2 |
Re: Starter issue Maybe?
Yeah it would about have to be something in the column
unplug it at the bottom of the column and see if it does anything |
08-04-2014, 07:59 PM | #3 |
Thanks, That worked. I only unplugged the left side. I left the other one attached. I guess I need to trace those wires and see where the problem is. I actually just replaced that switch at the base of the column a couple weeks ago
08-04-2014, 09:14 PM | #4 |
