08-04-2014, 07:18 PM | #1 |
Truck is running HORRIBLE!!!!
https://www.youtube.com/watch?v=deBKSGFgPuc
It won't stay running, every time I put my foot on the gas. I literally have to keep pepping the pedal and it dies It has NEW New Spark Plugs New Spark Plugs wires New Ignition Coil New Fuel Pump New Fuel line New fuel filter(I think) Carburetor has been rebuilt Could Points be bad? I'm tired of messing with it, it keeps doing weird crap
1971 GMC Sierra 1959 GMC 100 |
08-04-2014, 07:30 PM | #2 |
Re: Truck is running HORRIBLE!!!!
Did it EVER run right after you (or someone) rebuilt the carb?
PS: I hate to be the bearer of more truth than you want to face, but "it" isn't "doing" anything. It runs the way it's left to run based on who is diagnosing it and working on it. If you actually inure out what is wrong and address it correctly, it'll run like a Swiss watch.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
08-04-2014, 07:35 PM | #3 |
So what has changed between your "test drive" video, and now? Just the things listed?
I would verify proper fuel pressure at the carb, make sure after the carb rebuild something didn't get lodged inside to cause a blockage, Make sure float, idle needle, and butterfly are set correctly. I'm guessing you have firing order and timing set correctly after the new plugs, wires, coil etc... |
08-04-2014, 07:39 PM | #4 |
Timing isn't set to the right but its right near where it was
Firing order is in place How do I check without the Gasket tearing? It ran for a while after we fixed the fuel issue
1971 GMC Sierra 1959 GMC 100 Last edited by SCHRUMGMC; 08-04-2014 at 07:45 PM. |
08-04-2014, 07:52 PM | #5 |
I'd get the timing set right. Mine ran kinda like yours before I got my timing dialed in.
08-04-2014, 08:21 PM | #6 |
I will be buying a new Vacuum advance soon as well
08-04-2014, 08:42 PM | #7 |
#16876
Aluminum heads will fix that.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
08-04-2014, 09:39 PM | #8 |
"It ran for a while after we fixed the fuel issue"
I have no idea, but I say you have the fuel issue again...
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
08-04-2014, 11:57 PM | #9 |
I'm thinking it is the fuel filter
08-05-2014, 10:55 AM | #10 |
how much fuel are you keeping in your gas can?
I was asked but not answered did everything in your list change after the "test drive"? It is asked to help narrow it down. That is alot of changing but it must be one of those items it they all changed.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-05-2014, 11:24 AM | #11 |
1. Change the fuel filter (s) I used to carry two spares in my 71 because the tank had crud inside that I couldn't seem to get flushed out.
2. If you haven't got a filter in the line between the tank and the fuel pump put one in. That will keep dirt out of your fuel pump. 3. When the carb was rebuilt, were the settings very carefully checked and set correctly for that engine? I've seen some so called rebuilt carbs where the guy who did it just took the thing apart and replaced the pieces and put it back together without setting float level or other adjustmemts. 4. If you didn't correct the source of the dirt that got in the carb the first time you probably just got more dirt right back in it. These are all things I have run up against time and again over the years, some on my trucks or cars and some on other's rigs that got drug to me to be repaired after someone else "worked" on it. When I was Teaching High school autoshop it was pretty common to have local people drag in cars or trucks with problems that no one could get fixed right for us to work on. That was quite often when they had tried to do something with the carb or ignition and couldn't get it to work.
08-05-2014, 12:26 PM | #12 |
Do yourself a favor and use the correct fuel tank you have. Install it and throw that POS red plastic can in the dumpster. That would be a good start to fixing your issues.
08-05-2014, 03:26 PM | #13 |
Work on one change at a time, doing too many at once exponentially increases the number of issues. I would do them in this order:
1. Clean and install real gas tank. Might be fuel pressure issues with the location or size of the plastic unit. Install the fuel filters per previous comments. 2. You know it runs, get it to idle, in the video is sounds like it will not idle. Could be as simple as turning the idle speed screw on the linkage. I also assume you have the choke hooked up, that will affect the idle and throttle response when cold. 3. Once it idles if it still dies or stumbles when you push on the gas it usually is a)choke setting if cold; b)accelerator pump or c) vacuum advance. Check the choke to make sure it is closing all the way when cold. Look down the carb to make sure you are getting a shot of fuel when you open the throttle. Use a timing light to make sure the advance is working. It might not be the vacuum advance, there is also a mechanical weight system that could be gummed up, timing light will tell you if it is advancing. Just make a mark on the bottom pulley and see if it moves when you give it throttle.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-05-2014, 05:03 PM | #14 |
As well as the above:
Sounds like a 6 w/ monojet or similar with a bad vacuum leak, or not getting fuel. Might see if the vac advance hose is off or broken if there is one. Crank up the idle speed (not mixture) screw til it runs and spray come carb cleaner on the base of the carb to see if it improves, indicating a vacuum leak. |
08-05-2014, 07:38 PM | #15 |
I keep a good amount in the tank
Saw this truck today I have a new vacuum line being installed partially(in the works) The people are possibly coming tomorrow to do a story on my truck I'll change out the fuel filter and see what it does Video of the truck http://www.youtube.com/watch?v=zgdA6...ature=youtu.be
1971 GMC Sierra 1959 GMC 100 Last edited by SCHRUMGMC; 08-05-2014 at 07:49 PM. |
08-06-2014, 09:24 PM | #16 |
I figured that
I think it is really carburetor related
08-06-2014, 09:28 PM | #17 |
What does this mean? "I have a new vacuum line being installed partially(in the works)"
08-06-2014, 10:42 PM | #18 |
Meaning I've partially installed it
08-06-2014, 11:08 PM | #19 |
Only one end is hooked up.
Sorry, I couldn't resist. |
08-06-2014, 11:20 PM | #20 |
Oh..really now? I'm busy currently. I help a man with parkinsons as much as possible, help my grandmother.. am unable to work due to health issues.. Think its funny now? I teach myself things, its trial and error constantly..
anyway, all I have to do is flare the end to it and install it Having some issues routing it with the oil canister location.. I'll take more time to work on it as I am busy
08-06-2014, 11:56 PM | #21 |
Was the vacuum line uninstalled and open when you were having the problem? If so that is the problem, no advance and a vacuum leak (if the port on the carb is not plugged). If not you have eliminated another variable assuming the distributor advance is working.
08-07-2014, 12:05 AM | #22 |
Yes, it was plugged.. I am thinking the carb wasn't rebuilt correctly
08-07-2014, 12:11 AM | #23 | |
Catchy title goes here..
Thanks and good luck |
08-07-2014, 07:21 AM | #24 | |
When it comes to fuel delivery it's either a bad line, fuel pump or it's the carb, every single time
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
08-07-2014, 09:29 AM | #25 |
I am not familiar with these engines as much as others. So your entire vaccum line is a "hard" line? Can you run a rubber hose to simplify things? I know hard lines can be a pain to fit correctly then get them to seal up right. I still bet this has alot to do with the running issue. I bet when it is all hooked up it will make a world of difference.
