Old 08-04-2014, 09:45 PM   #1
surfmurf
Location: unincorporated Pinellas County, FL between Clearwater & Largo, FL
55.2 rear frame Gas tank
Wish suggestions for a GOOD FIT for a '55.2 3100 rear frame gas tank mount.
1 - My initial idea was to mount a tank between the rear frame rails that has a right SIDE, front gas filler that I could duct to the original Cab gas filler cap. I intended to run the gas lines either inside or outside the driver's side frame.
I have not been able to locate a tank to do this with over the past about 2 years.
2 - If it is impossible to locate a tank for this design, then my next choice is a tank also for a rear frame rail mount for a rear license plate area fill tank and probably a step bumper.
Any ideas for an old man guys? Murf
surfmurf is offline   Reply With Quote
Old 08-05-2014, 08:06 PM   #2
_Ogre
_Ogre's Avatar
Re: 55.2 rear frame Gas tank
most vendors sell gas tanks for 55-59 trucks, you can order them left, right, back or top fill
i doubt that you could fill the tank thru a 6 ft filler neck though
ideally find a panel/burban tank to mount in the stock location, next to the drive shaft
they are rare as hens teeth and probably priced accordingly
shop air compressor timer
Old 08-11-2014, 06:09 PM   #3
surfmurf
Hi Ogre; My old brain has forgotten if I responded to your info e-mail. I have beat the web replacement and custom sites and catalogs to death over the past 2 years but not found a suitable Gas Tank for my rear frame relocation, especially one that is not too tall (<8" = to clear road hazards). I had forgotten all about inside the frame rails (need to re-check my exhaust routing) & need to re-measure for outside (not preferred) and for the rear locations as I have misplaced my measurements. I do not care for it being IN the cab, it interferes with my Console idea.
I have not scoured the junkyards yet. Wanted a new tank as a 1st choice.
Have to re-investigate the Cab fill idea again, not sure I can get an adequate slope that is also sheltered (like by the frame rails). Thank you, Murf
Last edited by surfmurf; 08-11-2014 at 06:20 PM. Reason: Fingers pressed wrong keys - not my fault ! ! !
55.2 gas tank, relocate 55.2 gas tank
