Old 08-04-2014, 10:08 PM   #1
Irishbleueyes
Shift Indicator for PG to TH350 swap
Can we get just a lens to fit the shift indicator frame with the PRND21? Or will the lens or frame and lens from say a 1970 bolt on? I did a search but didn't find. Thanks for the help..
Irishbleueyes is offline   Reply With Quote
Old 08-05-2014, 03:32 AM   #2
grs
Re: Shift Indicator for PG to TH350 swap
I would like to know too.
grs is offline   Reply With Quote
Old 08-05-2014, 11:46 AM   #3
Irishbleueyes
I did find one, TruckandCarshop.com has a lens for th350 or 700r4. They run $22 bucks
Old 08-05-2014, 01:29 PM   #4
1963c-10
1963c-10's Avatar
The columns are different and plenty of people here have used the modern transmissions on the powerglide column, but the selector is off since the column was for a 2 speed. I'm not sure that just changing the lens to a 3 speed auto is going to correct the issue. I'll see if I can find one of the old threads on this.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-05-2014, 09:47 PM   #5
ms2335
ms2335's Avatar
Got mine for 700r4 at shiftworks it was for a 60's chevy impala
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 08-06-2014, 04:40 PM   #6
forestb
forestb's Avatar
Even after you get the new lens and the shifts are so off it doesn't really matter. I got mine to line up with park and drive and that is about it.
forestb is offline   Reply With Quote
