Old 08-04-2014, 10:59 PM   #1
67Steven
67Steven's Avatar
6L80 Tune (2-> 1 downshift questions)
New to the tuning world and I have been reading what I can, but I would like to address this one issue now if possible.
I am having an issue with the 2nd to 1st downshift- I basically need to bring the truck to a stop or nearly so before it shifts down.
It's terrible if you are rolling into a red light and it turns green. The transmission will either stay in second and lug, or lurch into first usually at or below 2 mph.
I have not changed a thing from the tuner I had do the original work. From looking at other 6l80 tunes, most 2->1 shifts (in Normal) are 7-9 mph @ 0% throttle, where mine is at 20 mph and doesn't occur until 1-2 mph. Am I reading that correctly? Should I look elsewhere for downshift properties?
Any pointers would be appreciated.
Well, I can't attach the file as it is too large (sheesh!)
http://www.filedropper.com/1972blazer
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744
67Steven is offline   Reply With Quote
Old 08-05-2014, 06:34 AM   #2
aknovaman
Re: 6L80 Tune (2-> 1 downshift questions)
Lower the settings to 7 mph and it will be fine.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 08-05-2014, 08:06 AM   #3
67Steven
67Steven's Avatar
I will give it a try, thanks.
I would like to know the 'why' behind the 'do' part if you or anyone could briefly explain- I like to learn this stuff for future use!
Old 08-05-2014, 01:29 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Afaik, its because there isn't the same capacity for overrun that the 4speeds had, due to the design of the internals. The 6l80e's are clutch-to-clutch, and setting too high of a downshift speed would cause more slip between clutches then allowed, and it would probably want to try and shift right back up.
Thats how I understand it from the reading. 6l80e's confuse the crap out of my because the Truck,car,and 'vette's were all setup and programmed a little differently.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-06-2014, 09:48 AM   #5
67Steven
67Steven's Avatar
Thanks for the information. I thought it might have something to do with wanting to up-shift or the the TCM saves itself from destruction by not allowing the downshift at too high of speed.
It makes me wonder what else is wrong in the tune...
Old 08-07-2014, 07:52 PM   #6
Hart_Rod
Hart_Rod's Avatar
Steven,
email me a copy of your tune and I will take a look at it, r.
R
Edit: just noticed you posted the tune above.
Hart_Rod is offline   Reply With Quote
Old 08-07-2014, 08:24 PM   #7
Hart_Rod
Hart_Rod's Avatar
Steven,
I downloaded your tune and then downloaded a factory 2008 GMC Sierra 6.2/6L80 tune and then did a compare between the two. It looks like the guy that did your tune has some stuff jacked up in the auto shift sections of the tranny tune.
Old 08-07-2014, 09:24 PM   #8
Hart_Rod
Hart_Rod's Avatar
Steven,
Make these changes to your tune and let me know what you think.
R/
Old 08-08-2014, 05:26 PM   #9
67Steven
67Steven's Avatar
Originally Posted by Hart_Rod View Post
Steven,
R/
Sweet, thanks! I just got back in town, and I will load it and try it out. I will let you know!
Old 08-08-2014, 10:52 PM   #10
67Steven
67Steven's Avatar
Just went for a short test drive and it is a night and day difference, thanks!
No more 1st gear 5000 rpm shifts at 3/4 throttle!!
It seems to go around corners in the correct gear now, too.
I would like to stay in first just a hair longer, and second seems to drop off fast. Should i change the 1->2 and 2->3 shifts to a higher number on the throttle % chart?
Thanks again for your help.
