Old 08-05-2014, 02:22 PM   #1
shok
Question for converting my brakes to dual circuit
This is for my 66 c10. Two questions about switching to dual circuit, but still non power and drums all around.
1) Are the fittings the same size throughout the whole system? Like if I go to the store with my old soft line and the hardline there fits it then its guaranteed it will fit the master cylinder? (plan to use the same MC Sharps used, Impala model I think.)
2) Can I just make life easier by buying some brake line kit that has everything to restore the brake lines on a later model dual circuit truck instead? I'm on a budget but its worth considering.
I have the tools to cut and flare the lines already if that factors in the answer.
Thanks!
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 08-05-2014, 04:23 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Question for converting my brakes to dual circuit
I found quite a few threads on splitting brake lines, I'm not sure if one of these threads might help;
http://67-72chevytrucks.com/vboard/s...d.php?t=502413
http://67-72chevytrucks.com/vboard/s...d.php?t=460791
http://67-72chevytrucks.com/vboard/s...d.php?t=487384
http://67-72chevytrucks.com/vboard/s...d.php?t=467515
66 C20 Service Truck:
Old 08-06-2014, 12:41 AM   #3
shok
thanks i'll go thru those
Old 08-06-2014, 12:59 AM   #4
rhm63
I just did this on my 63. I just asked for a drum/drum non-power master cylinder at the part store.They search the computer for c10s, and it ended up being a master cylinder from and early 70's c10. '71 I think.
I bought a generic brake line kit on Ebay.
I replaced the wheel cylinders too.
The brake stuff for these trucks seems to be cheap.
The only hard part was finding new T-blocks locally. And you may have to lengthen the pedal push rod. I used coupling nut and a short piece of threaded rod.
rhm63 is offline   Reply With Quote
Old 08-06-2014, 01:20 AM   #5
shok
could you give me an example of the brake line kit you ordered from Ebay?
Old 08-06-2014, 08:02 AM   #6
PGSigns
PGSigns's Avatar
If you lines are in good shape it is an easy split. On the passenger side there is a tee with the line going to the back. Remove the line going to the back and put a plug in the tee put a union on the line going to the back and run a new line to to the new master cylinder. All the fittings and lines will be 1/4"
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-06-2014, 08:25 AM   #7
66Submarine
66Submarine's Avatar
'71 is not right; '71 and up is a front disk brake setup. You need an earlier '67-'70 MC for 4 wheel drums.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 08-06-2014, 10:34 AM   #8
rhm63
I cant find the exact brake lines I got. It was something like this from the same seller. Basically just a bunch of lines of different length. It is enough to do 1.5 cars, several pieces left over. The rubber lines are same as stock.
http://www.ebay.com/itm/Metal-brake-...8349df&vxp=mtr
The master I got was a for a 1970 c10. But I don't remember it being this expensive.
http://www.oreillyauto.com/site/c/de...1292&ppt=C0066
Old 08-06-2014, 10:46 AM   #9
NEWFISHER
NEWFISHER's Avatar
inlinetube.com
Super easy, fits exactly and has all the correct fittings when you give them your application along with what system you will be using i.e. disc/drum....disc/disc etc. Dont forget the $11.00 frame clip kit, easy to keep them protected.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 08-06-2014, 03:58 PM   #10
shok
Thanks for all the info everybody. I'll look at the links, if I go the FLAPS route at least I know what size line and fittings to get now, I hate running back and forth to the store for little stuff like that.
Old 08-06-2014, 08:35 PM   #11
66Submarine
BTW, Rockauto.com has those '67-'70 master cylinders new for $40.
