08-06-2014, 06:15 AM | #1 |
brake bleeding question
So I bench bled my brand new napa mc. Then installed. Started w furthest rear line using a self bleed kit. I pulled 3 reservoir full of fluid and still getting air. Is this normal?
08-06-2014, 07:06 AM | #2 |
Recovering Truck Driver
Re: brake bleeding question
I've never had one take that much fluid for a master cylinder change, I assume it went on a system that already had fluid in the rest of the lines from the old master cylinder. You might want to take it back off and see if it's leaking out the back.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
08-06-2014, 12:38 PM | #3 |
Get someone to help you and manually pressure bleed the system
08-06-2014, 01:03 PM | #4 |
On it! Thinking same thing.
08-06-2014, 01:32 PM | #5 |
20' Daredevil (Ret)
I had the same problem a year or two back and it drove me crazy -- I kept pumping fluid though and kept getting air from the rear wheel cylinders. I hadn't noticed any sign of leakage but closer inspection showed a very slight residue on the cylinders. Both of them were bad. New wheel cylinders made everything good.
