I Want Fatty Wheels
Helloo,
was checking out fatty wheels and i wonder how fat can i fit in my 1980 stepside without cutting out my body parts ? Thank you in advanced ![]() |
Re: I Want Fatty Wheels
The best way to find out is to hang plum lines from the fender lip, wheel mount surface, inner fender, and leaf spring. Take down all those measurements, then shop for tires that have a section width that will fit within those measurements, then shop for a wheel that will fit the tire that has the correct back space.
In my case, I bought the wheel and tire I wanted then built the truck to fit the tire.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Where are you finding fatty tires?
I'm lifted, so I don't have the clearance issues that you do, and we're obviously not looking for the same size tires, but I have been looking for years for some good, fat tires.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#4 | |
Another Q, know if i Get a back spacer i can get a more fatty one right ? |
im sorry, but wtf is a fatty tire? is that a brand ? or are you asking how to get a wide tire under your truck?
#7 | |
Pretty much anything bigger than a 295/50/15.
#8 | |
But its like a spacer that fits between the drums an wheels that pushs the ring outside the fender depending on the spacer size |
#9 | |
The One And Only !!!
If you want to keep fat tires inside the fenders you don't want spacers, You want a correct back spaced wheel measured like J Knight posted.......
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
I do not know if your into 20 inch wheels but they have wider like 325's
