08-06-2014, 10:49 AM | #1 |
for those running 327's 305's 350's
I have a 327 in my 65 c10 not the original motor to the truck
I have the alternator on the passenger side and a short water pump my alternator brackets broke so to my surprise everyone I called to replace the bracket said none show the passenger side mount with the short water pump. After ordering a couple brackets that didn't fit I had the broken brackets welded and I cleaned them up as best I could but they aren't as straight as I'd like them to be. Anyone know what car info I can give at the auto parts store so I can replace the brackets with new ones? |
08-06-2014, 01:13 PM | #2 |
Re: for those running 327's 305's 350's
Can you post a picture of what you have?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-06-2014, 01:23 PM | #3 |
Senior Enthusiast
These may be more than you want to spend, but Alan Grove makes a passenger side alternator bracket for the short water pump. Part number 213r SC - Alt.
http://www.alangrovecomponents.com/i...tions/213R.pdf http://www.alangrovecomponents.com/S...Short_Pump.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-06-2014, 01:53 PM | #4 |
not the best pic but gives you an idea
08-06-2014, 02:03 PM | #5 |
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-06-2014, 02:04 PM | #6 |
Senior Enthusiast
That's the same bracket I had on mine many years ago. I picked it up in a junkyard, but had no idea what car it was attached to. It might have been a Monte Carlo or Chevelle, Nova, etc. Sadly it's long gone or I'd send it to you:
08-06-2014, 02:07 PM | #7 |
looks like the long pump to me.
08-06-2014, 02:08 PM | #8 |
Looks like 73 up
08-06-2014, 02:08 PM | #9 |
Senior Enthusiast
Oops. Yes mine was a long pump. Perhaps the broken one is on a long pump as well, or perhaps the same bracket fits on either one?
08-06-2014, 02:09 PM | #10 |
Looks like 73 up.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=181
08-06-2014, 02:14 PM | #11 | |
I ordered the bracket from summit and the mount for the bolt where it mounts to the front of the water pump was stretched a few inches forward for the long pump. when I called them they said all short pumps are driver side mounted and long pumps were passenger side mount so when I explained I had passenger side with the short pump they said, "HUH how about that?...sorry" |
08-06-2014, 02:19 PM | #12 |
i don't believe you are going to find a short pump with the heater outlet at the top and a boss for the bracket
08-06-2014, 02:20 PM | #13 | |
you de man I am going to place an order right now. thank you |
08-06-2014, 02:47 PM | #14 |
That lmc part looks like a long pump bracket. I did not think that the alternator would fit up there with a short pump. Sure would like to see a pic of your setup from the drivers side to show your pump and the bracket.
Jimmy
08-06-2014, 02:58 PM | #15 |
you are correct I just cancelled my order, I was so excited! I guess I could go to a long pump if I need to, I just hate spending money on this set up when I know there is an LSX with my name on it somewhere waiting to come forward.
08-06-2014, 04:50 PM | #16 |
Speedway motors is where I got mine.
http://www.speedwaymotors.com/Search...ackets%20chevy
08-06-2014, 05:13 PM | #17 |
i got home from work and took a few pics from up under her dress while she was sleeping
08-06-2014, 05:20 PM | #18 |
one more
08-06-2014, 05:57 PM | #19 |
08-06-2014, 06:15 PM | #20 |
88
08-06-2014, 06:29 PM | #21 |
Yeah, it looks like the long one to me; have you actually checked it? Here's a picture of a short waterpump.
08-06-2014, 06:34 PM | #22 |
08-06-2014, 06:37 PM | #23 |
Measure it and see. Here's another long WP picture:
08-06-2014, 06:40 PM | #24 |
I'm on a roll stealing pictures today!
08-06-2014, 06:47 PM | #25 |
here is mine
