Old 08-06-2014, 04:50 PM   #1
chevyrestoguy
chevyrestoguy's Avatar
Emergency Brake Cables
For those who have upgraded to a later ('73-'87) rear end, what did you do for an emergency brake (notably, cables)?
I'm asking this because my '79 12-bolt has short e-brake cables due to it originally being a leaf spring rear end. Will a cable set from a '67-'72 half-ton work? I will need to build a trapeze linkage (1 cable in, 2 cables out to the rear end) because I have completely changed the entire drivetrain and crossmembers and although I used mostly factory parts from different years, nothing is in the stock 1964 configuration.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-06-2014, 06:09 PM   #2
earl84
Re: Emergency Brake Cables
I am going to have to do this as well. Plan on doing something like azdeltawye did in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=624445 , see Post 6
earl84 is offline   Reply With Quote
Old 08-07-2014, 05:03 AM   #3
Woogeroo
The 60-66 FAQ Index
Section 2B
Brakes
various park brake threads
66-72 park brake system thread swap
Good luck,
-W
Woogeroo is offline   Reply With Quote
Old 08-07-2014, 02:41 PM   #4
chevyrestoguy
Thanks, Woog! That's exactly the information I was looking for. I use your guide all of the time, and I don't know why I didn't check there first.
My build threads:
